Latest: tbafonso
Overall: 17130
Online Now [252]:
Visitors: 250
Members: 1
Today: 18202
Total: 103986135
Forums › The Car › 206 Problems › Engine codes
Engine codes
Deano
PostPosted: Thu Nov 22, 2012 6:01 am Up
Hi I need a new block for my 206 when I look on eBay they is a few blocks but with diffrent engine codes will I have to get one with the same code as mine if so where will I find my engine code it's a 2002 2.0 138 bhp Twisted Evil
iainlovatt
PostPosted: Thu Nov 22, 2012 6:26 am Up
i have a 1999 gti engine for sale?
(My Garage)
Deano
PostPosted: Thu Nov 22, 2012 7:06 am Up
I want something with low miles mate as mine has only done 53 thousand I am looking at one there that has only done 38 thousand for 220 that's delivered to my door step aswell
PostPosted: Thu Nov 22, 2012 7:13 am Up
Think yours will be a RFR engine.
You could always enter your VIN on servicebox and get the full vehicle characteristics that it left the factory with.
iainlovatt
PostPosted: Thu Nov 22, 2012 7:16 am Up
It would cost me 40 quid for a lift and 50 for delivery. I cant go any lower than £250 collected including all bit you will need.
(My Garage)
Deano
PostPosted: Thu Nov 22, 2012 7:58 am Up
How many miles it done though
PostPosted: Thu Nov 22, 2012 12:32 pm Up
2002 is an RFN - which it says on the VIN number in the windscreen.
I don't think there is a difference between RFR and RFN engines. Electrics differ because of the additional downstream lambda sensor on the RFN but otherwise....
Deano
PostPosted: Thu Nov 22, 2012 3:57 pm Up
rfn it says on my vin would it matter what block i got or would any 2.0 16v 138bhp fit in any 206 gti 140 after all its only the block i am changing
PostPosted: Fri Nov 23, 2012 2:01 am Up
I dont think it matter as i've never seen a difference with the engines. Don't quote me on that though. Maybe it's an internal change. If there is one it's not obvious.
Deano
PostPosted: Mon Nov 26, 2012 2:31 am Up
Cheers mate what do u get better if u mod your throttle bodie
