Latest: morgan20
Overall: 17135
Online Now [126]:
Visitors: 125
Today: 12551
Total: 110564823
Forums › The Car › 206 Problems › Power steering pipe
Power steering pipe
Deano
PostPosted: Sat Nov 24, 2012 11:27 am Up
Does anybody know how to get the power steering pipe off the top of power steering fluid bottle on 2.0 140 I have cracked it but the whole pipe wants to spin but it can't because it still attached underneath
macj
PostPosted: Sat Nov 24, 2012 11:55 am Up
a bit of WD40 on the pipe/nut joint.... then you need to be brave
boardinbob78
PostPosted: Sat Nov 24, 2012 11:57 am Up
Not sure but my 180 has hole in pipe too, located leak today right under car behind engine, going into local garage Monday hope it ain't too expensive!
Deano
PostPosted: Sat Nov 24, 2012 12:00 pm Up
So the nut at the top with the pipe going threw should spin
macj
PostPosted: Sat Nov 24, 2012 12:02 pm Up
yip............ it stays on the pipe which is flared on the underside of the nut
Deano
PostPosted: Sat Nov 24, 2012 12:03 pm Up
If the leak is on the rubber bit just cut the damaged bit out and get a bit of pipe that fits inside and 2 jubilee clips nice And cheap if not it will be full pipe front to back get one from scrap yard should not be too dear to do mate
macj
PostPosted: Sat Nov 24, 2012 12:05 pm Up
not wishing to be a party pooper but you should never bodge steering ..... just a thought and no offence meant to either party
Deano
PostPosted: Sat Nov 24, 2012 12:38 pm Up
No offence takin just a cheap temp fix and ye your right u should not bodge steering
Deano
PostPosted: Mon Nov 26, 2012 6:23 am Up
Or we'll mine snapped might aswell change I why engine out of way b*$****d
