Forums › The Car › 206 Problems › Pagid Discs and Pads- Euro Car Parts - Confussed?? |
Posted: Tue Nov 27, 2012 10:26 am |
Trade Rating: +13
Edward wrote: |
Have you used the Euro Car Parts discount code? |
Pagid30?
Posted: Tue Nov 27, 2012 11:50 am |
midmonth31
Posted: Wed Nov 28, 2012 4:42 pm |
My sufferings ended when I went to www.brakesint.co.uk . First find your pads (remove your pug's wheel to see exactly which types of brake system pads you have)
Then find a matching set of disks by looking your pads up in a catalogue of either www.mintex.co.uk or www.brembo.com
It is crucial to do the above, as different brake systems might be fitted on same engine same year type Peugeots! And then you end up with 0.5mm thicker disks which don't fit in
All the best with your quest!
Posted: Thu Nov 29, 2012 8:53 pm |
there's also another for batterys it is battery15 for 15%
Posted: Fri Nov 30, 2012 2:06 am |
Is this subject really still going? Have the new bits been bought yet? It's possibly the easiest items to buy correctly.
Posted: Fri Nov 30, 2012 2:39 am |
Trade Rating: +13
Yea got Vented discs and pads from local place £50.00 total (Vented discs x 2 + pads) Not to bad. Just got to fit them now. Jobs are piling up. Stupid weather!!
Posted: Fri Nov 30, 2012 7:22 am |
I bought drop links, wheel hub and bearing, abs sensors, all filters etc.they all fitted fine, buy when brake disk doesn't fit by a fraction, and ordered kit states your make model engine and year, wouldn't fall in an easiest-items-to-buy-correctly category
Posted: Fri Nov 30, 2012 7:26 am |
Trade Rating: +13
sledge wrote: |
when brake disk doesn't fit by a fraction, and ordered kit states your make model engine and year, wouldn't fall in an easiest-items-to-buy-correctly category |
