Latest: Puggingalong
Overall: 17129
Online Now [323]:
Visitors: 322
Today: 45329
Total: 101338250
Forums › The Car › 206 Problems › GTI ABS fault
GTI ABS fault
iancav6
PostPosted: Sun Dec 02, 2012 8:49 am Up
The ABS on my 2002 GTI had started to occasionally cut in when travelling less than 10mph and generally when turning right.Had a look under it today and found the O/S driveshaft large diameter retaining clip had split allowing the boot to slip off the CV joint when steering applied.As the ABS sensor is at the back of the hub,I think the boot was interfering with the pick up and trigger ring.
Put a temporary tie-wrap on until I can get a metal clip.
xx
bezford
PostPosted: Tue Dec 04, 2012 7:58 am Up
What does that feel like then?when it cuts in?
R.HYDE
iancav6
PostPosted: Tue Dec 04, 2012 1:32 pm Up
It feels like the brakes don't work at all.I think the boot confuses the ABS unit, it probably thinks the wheel it fully locked up as it doesn't see the trigger ring rotating.
xx
DREWDEN
PostPosted: Tue Dec 04, 2012 9:56 pm Up
Reluctor ring not cracked? Had same problem, mine was cracked.
206 2ltr Hdi glx 53 plate
SinfulDesignCom
PostPosted: Tue Dec 04, 2012 10:33 pm Up
Had the same issue - sounds a lot like the ring to me...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
iancav6
PostPosted: Wed Dec 05, 2012 3:09 pm Up
I have driven it about 70 miles since and it has been fine, when it would do it at least once a day before.
It only ever did it when turning right at low speed,if it was a reluctor ring it would be all the time and at any steering angle?
i will have clocked up another 100 miles by the weekend,if it hasn't done it by then,the boot was the problem.
xx
