Posted: Tue Dec 04, 2012 5:40 pm |
Currently got 2 split abs rings on the GTi thought it would be new shafts to solve this, but just found these on ebay... www.ebay.co.uk/itm/PEU...27c015a634 Anybody ever used anything like these? Any experience with just fitting the ring to an old shaft?
Anybody able to think of any problems I'm likely to encounter?
Posted: Tue Dec 04, 2012 5:43 pm |
I don't know about them (never used them), but i'm 90% sure that the abs rings are part of the CV joint, which you can change separately to the shaft.
Posted: Tue Dec 04, 2012 5:45 pm |
just make sure where they fit on the CV is clean and and rust free.
if you have a gas cooker heat them up and they basicly drop on
Posted: Tue Dec 04, 2012 5:56 pm |
Don't have gas here, do have a blowtorch handy though, think they should be okay then cartoonhead?
and pug206lx the ABS ring sits on the end of the drive shaft just behind the brake disc.
They have a 2 year warranty on them as well so might as well give them a go for that price. See if that stops my dashboard being like blackpool illuminations, just the anti-polution fault to sort then.
Posted: Tue Dec 04, 2012 6:40 pm |
yup a blow torch would be enough to warm it up to expand it.
Posted: Tue Dec 04, 2012 6:55 pm |
Sorted, shall get them on order then get rid of a couple of faults. Just the p0420 to fix next
Posted: Wed Dec 05, 2012 2:53 am |
I spot welded mine on. Worked a treat.
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Wed Dec 26, 2012 3:15 pm |
How did you get on with this out of interest... Both of mine have just cracked in the last week!
Posted: Wed Dec 26, 2012 3:55 pm |
I have used these rings, got a garage to put em on but they work just as well as any other rings
