Latest: SA01
Overall: 17138
Online Now [2460]:
Visitors: 2459
Today: 484655
Total: 111798815
Forums › The Car › 206 Problems › Dial Problem
Dial Problem
PostPosted: Wed Dec 26, 2012 2:22 pm Up
Hello All,
I have this problem happen today,this morning,we had a cold weather,and I tried to start the car after not using it for few days,but it didn't start,I tried to start it 3 times,and each time the engine starts a half start and then turn off,while the needles of the cluster flickering.
So after checking the problem was almost a dead battery :(,but that costed me a faulty Temp. gauge and brand new battery,sp here is a few pics of the faulty gauge,so I hope you can help me to fix it,because I'm thinking of taking the speedo off,and adjust the needle to it's original location,because of having such a faulty gauge can cause me problems,if the car temp. got too high,I can't know that ,because it will be showing 70 all the time Sad
Thanx
anton1989
PostPosted: Wed Dec 26, 2012 2:44 pm Up
Trade Rating: +16
i have this problem on mine. also have it on the fuel gauge no idea why, let us know if you sort it
PostPosted: Wed Dec 26, 2012 3:08 pm Up
Will keep you posted mate :),Merry Christmas Smile
PostPosted: Wed Dec 26, 2012 3:35 pm Up
So the gauge just keeps flikering up and down ever so slightly?
It is either the speedo cluster at fault but just check the system for other faults as an ABS ECU failure caused one (supposedly)
Rob2859
PostPosted: Wed Dec 26, 2012 5:48 pm Up
If it turns out to be the cluster before you throw it away take the mileage counter out for me please Wink
bezford
PostPosted: Thu Dec 27, 2012 8:03 am Up
Defo try a bsi reboot...see on HOW TO forum for steps...
R.HYDE
PostPosted: Thu Dec 27, 2012 5:11 pm Up
It just flikered when I tried to start the car,and it didn't start,then what you se e in the pic happen,so it moves fine when the temp. goes up,but the mark for me now is 70oC instead of 90oC Sad
I have pp2000,and I tested the the temp. gauge,and it's says "Cycle Complete" which mean nothing faulty with the gauge but it's location,so i will try to reset it manually
PostPosted: Thu Dec 27, 2012 5:12 pm Up
how did you know that my car Mileage counter is less than yours ;)..heheh
PostPosted: Thu Dec 27, 2012 5:14 pm Up
Well I got a new battery fitted,which mean i done the safe reboot already,and no joy Sad
Rob2859
PostPosted: Thu Dec 27, 2012 7:19 pm Up
I am pretty certain. I am on 115 or something. Its only the screen I need so it doesn't matter anyway. The rubber/ribbon on mine broke off.
PostPosted: Fri Dec 28, 2012 12:28 pm Up
Mine have 96650 on the clock :D,but bad news for you is that I fixed it today :),so bad news for you,and good news for me..heheheh Very Happy
PostPosted: Fri Dec 28, 2012 12:29 pm Up
Got it fixed today,will post a how to on the weekend :),all working great now Wink
Rob2859
PostPosted: Fri Dec 28, 2012 10:03 pm Up
Good job anyway!
PostPosted: Sun Dec 30, 2012 2:31 pm Up
Rob2859 wrote:
Good job anyway!
Thank you Very Happy
bezford
PostPosted: Sun Dec 30, 2012 10:35 pm Up
How did u fix it then marra???
R.HYDE
