Latest: tbafonso
Overall: 17130
Online Now [511]:
Visitors: 510
Today: 66009
Total: 104033883
Forums › The Car › 206 Talk › How low before I run into problems?
Paddy1795
PostPosted: Mon Jan 14, 2013 2:13 am Up
Alright guys,
Just wondering if there's a point in lowering a 206 in which I'll have to change tyre profile/wheel size? And what that point is?
I'm looking to buy coilovers that drop from 20-60mm, so would I have any trouble at the maximum of these?
Thanks for any replies,
Paddy!
PostPosted: Mon Jan 14, 2013 3:28 am Up
Whats the point in lowering? Why would you have to change your wheel size?
Paddy1795
PostPosted: Mon Jan 14, 2013 4:22 am Up
It looks nice, and handling could be improved. Because if the arches get too low, the wheels will rub the wheel.
Big_Rich180
PostPosted: Mon Jan 14, 2013 4:23 am Up
If you go too low the handling will be ruined.
If you want it for looks drop JordGJ a PM, his looked pretty damn good.
www.206info.co.uk/Foru...50180.html
-Dave-
PostPosted: Mon Jan 14, 2013 4:29 am Up
Trade Rating: +36
www.206info.co.uk/Foru...guide.html
Ex 206 Owner.
Paddy1795
PostPosted: Mon Jan 14, 2013 4:30 am Up
Well I kind of want the middle ground to be honest, ideally I think a 30-40mm drop for daily driving, and then as low as I can go for meets etc.
I'll give him a PM when I get home from work, loading the page up takes ages haha.
Cheers man,
Paddy!
Big_Rich180
PostPosted: Mon Jan 14, 2013 4:31 am Up
Problem being that you will have to adjust the torsion bar every time you want to lower the back which is a pain in the a**e.
Paddy1795
-Dave- wrote:
http://www.206info.co.uk/Forums/viewtopic/t=30818/highlight=lowering+guide.html
Cheers mate, I'll have a read through this when Im home from work!
Paddy!
Paddy1795
PostPosted: Mon Jan 14, 2013 4:59 am Up
Yeah that's true, but it wont be that regular that I will want it really low, and after getting it done properly at a garage once, Id trust myself and a mechanic mate to do it in his garage I think, I'll just make sure that the garage oil everything up well to make the job easier next time.
Mike_XS
PostPosted: Mon Jan 14, 2013 6:00 am Up
40mm is a good drop. Mine's down 40mm and the handling improved a lot! Components will wear out quicker, the main one probably being the drop links. You won't need to change the wheels, some of the guys on here drop between 80-100mm, 40-60 really isn't much compared to that. You will need to get the tracking done, I think mine was out by around 8% after the drop. Any lower than 40mm and the handling will get worse.
Paddy1795
PostPosted: Mon Jan 14, 2013 7:10 am Up
Right, well I imagine 40 would be the maximum drop Id have for daily driving, I live on a cobbled street with raised drains so probably couldn't get away with it being much lower!
How much was it to get the tracking sorted mate?
Thanks,
Paddy!
