Latest: Beduff1977
Overall: 17134
Online Now [745]:
Visitors: 744
Today: 115037
Total: 108050223
Forums › The Car › 206 Problems › car wont start
car wont start
Go to page Previous  1, 2
PostPosted: Sat Jan 19, 2013 12:44 pm Up
Is your fuel pump priming?
zezotornado
PostPosted: Sat Jan 19, 2013 1:07 pm Up
yes it is
I called a technician but he is not in my city he said that the the problem is the fuse box and i have to replace it
is it possible ?
PostPosted: Sat Jan 19, 2013 5:30 pm Up
Thats what I had to do, but I knew the fault. Have you got an engine light on? Even if not I bet there's a pending code problem stored. I wouldn't guess at the problem. See if you can get it code read.
zezotornado
PostPosted: Tue Jan 22, 2013 1:03 pm Up
Hi,
After i got very very annoyed from the problem i went to Peugeot dealer and they found the problem in the starter ( pic below ) and i replace it and now every thing is perfect .
thank you so much all of you for the help and i wrote this to make this post helpfull if any one face the same problem ( I hope not ) .
PostPosted: Tue Jan 22, 2013 2:09 pm Up
Sometimes the first point of action is a fault code read, unless the problem is really obvious! Although in saying that, a fault code can give you the run around, but its batter to have one than not, glad you got it sorted!
PostPosted: Tue Jan 22, 2013 2:14 pm Up
Nice to see it sorted. Once again the suggested fix leads pure diagnostic to a jumped conclusion!
DREWDEN
PostPosted: Wed Jan 23, 2013 7:10 pm Up
The 20amp-70amp fuses in the diagram for the (bsi, abs, fan unit etc) are located under the fuse box.
And are reveiled when you pull the fuse unit upwards out of its box.
Just thought i'd put this in for people who don't know this.
Would MrBsi just second this, because not sure with preplex.
Thanks Laughing Very Happy
206 2ltr Hdi glx 53 plate
PostPosted: Thu Jan 24, 2013 2:00 am Up
I think your right, there called maxi fuses,but the picture doesn't relate to the diagram on that link. Obviously wrOng diagram used. If those maxi fuses blow you've got a serious fault somewhere though
Page 2 of 2
