Latest: Stu-mill
Overall: 17131
Online Now [47]:
Visitors: 46
Today: 4147
Total: 104913809
Forums › The Car › 206 Problems › Cutting out
Cutting out
Duncan
PostPosted: Sat Jan 19, 2013 3:46 pm Up
Hi all,i am a newbie here,just purchased 206,1.4 and having issues with it cutting out as i come down into second to turn a corner,allso notice while stationary if i turn the steering the revs fluctuate up and down,any ideas greatfully recieved.
richpowell91
PostPosted: Sat Jan 19, 2013 4:00 pm Up
Check the idle control valve, take it out spray with some brake/parts cleaner. See if it still cuts out, if so take it along to a local garage and get them to scan it with a diagnostic machine and see if they can find anything to point you in the right direction.
The revs fluctuating is normal and down to the power steering.
Duncan
PostPosted: Sat Jan 19, 2013 4:04 pm Up
Cheers Rich,i had it on the diagnostic during the week as it was only firing on 3,indicating number 4 injector faulty,this has been changed and is running fine,it showed no other faults
richpowell91
PostPosted: Sat Jan 19, 2013 4:07 pm Up
Ah fair enough, try cleaning the idle control valve first then, also does it do it all the time when slowing or once every now and again.
Duncan
PostPosted: Sat Jan 19, 2013 4:24 pm Up
Now and again,for some reason it is only while i am turning,never does it while i pull up straight.
Rob206
PostPosted: Sat Jan 19, 2013 5:05 pm Up
I'm having same problem mate a dint have a clue what it is but it does my head in
PostPosted: Sat Jan 19, 2013 5:32 pm Up
Sounds very much like idle air control circuit steeper motor sticking.
The valve control the amount of air at idle.
When you turn a corner the power steering pump puts a load on the engine. That load will cause the revs to drop.
The ECU will see the revs start to drop and control the steeper motor to give slightly more air to compensate for that and idle should be constant regardless of turning the steering wheel.
The throttle body and ICV get coated in carbon and the valve sticks. You can clean them and it is usually successful.
"How to" are here:-
www.206info.co.uk/Foru...46523.html
www.206info.co.uk/Foru.../t=72.html
