Online Now [576]:
Visitors: 575
Today: 110976
Total: 105837562
Forums › The Car › 206 Problems › SPEEDOMETER
SPEEDOMETER
DREWDEN
PostPosted: Tue Jan 22, 2013 1:21 pm Up
Hi all
Just wondered if anyone could enlighten me, checked speedo whilst aproaching a speed camera, was doing 30ish, but speedo was showing 5mph. For the next half mile or so would fluctuate between 5-15 mph, even though i was traveling 30-40mph, then all of a sudden the car gave a surge of power and speedometer went back to normal.
Car been ok since. Hoping its just an hiccup with the ecu, and doesn't return.
Any answers, sugestions would be most appreciateive, just in case the problem returns. (as they normally do). Very Happy
206 2ltr Hdi glx 53 plate
PostPosted: Tue Jan 22, 2013 1:29 pm Up
Is your car multiplexed? And do you have any abs faults at the moment?
DREWDEN
PostPosted: Tue Jan 22, 2013 1:45 pm Up
Ye multiplex, and yes abs light been on 2 months or so, waiting to sort finances out, chrimbo and that, needs relucter ring f/ns. Spot on mate, is it ecu. Embarassed
PostPosted: Tue Jan 22, 2013 1:52 pm Up
Passenger side ring is cracked, on most of the multiplexed 206's this is what the speedo takes it's signal from. I have the same problem, every once in a while the spedo fluctuates when the abs reading isn't happy. New ring will fix both problems, nothing wrong with the ECU.
If you measure your driveshafts, I have 2 ABS rings sat in the garage brand new that I bought and found to be the wrong one's for mine. Your welcome to have them for what I paid for them.
DREWDEN
PostPosted: Tue Jan 22, 2013 2:17 pm Up
Thanks for replys, help, Lee, Priced complete half shaft up before christmas £60 gfs (return old one) £30 fitted by mate. Will let you know if i decide just to do ring.
Many Thanks
PostPosted: Tue Jan 22, 2013 2:42 pm Up
Really not worth the money mate, I got 2 rings for £10, typically mine were the smaller slightly more expensive one's. The right set cost me £16.
DREWDEN
PostPosted: Tue Jan 22, 2013 5:07 pm Up
Hi Lee, Meant full unit £60, 2 shafts (gearbox ,wheel) cv joint, gaiter, reluctor ring, all complete as one unit, to bang straight in.
Just that i read on here a lot about cv's going, mines never been touched, from car being new, (9years) this now bears the question how long do cv joints last, does it pertain to bad maintenance, driving habits, or just wear and tear, should i change mine even though its ok. Whats your thoughts Lee.
DREWDEN
PostPosted: Tue Jan 22, 2013 5:17 pm Up
CV Joints as long as there not permanently abused shouldn't cause any trouble. As long as there's no knocking/clicking/clunking from them and the gators haven't split then I would just leave them.
Taff!
PostPosted: Wed Jan 23, 2013 8:06 am Up
Was it just the speedo or was the rest of the instrument panel acting up?
206 1.6 Quiksilver
PostPosted: Wed Jan 23, 2013 8:31 am Up
This would be speedo taff, not related to your problem.
