Latest: Puggingalong
Overall: 17129
Online Now [152]:
Visitors: 151
Today: 101854
Total: 101613869
Forums › The Car › 206 Problems › damp - wind deflectors?
lottley93
PostPosted: Wed Jan 23, 2013 5:51 am Up
is anybody else having problems with interior getting damp because of Heko wind deflectors messing with seals? it might not be this just trying to narrow down... they're all properly fitted as per instructions i just cant help but feel its letting damp in.
otherwise any other recognised problem areas? car is getting more and more damp and mouldy!
cheers in advance.
Big_Rich180
PostPosted: Wed Jan 23, 2013 5:56 am Up
Are you sure its not down to the snow and crap on your shoes?
PostPosted: Wed Jan 23, 2013 6:01 am Up
Also short runs never allow the interior to get warm and start drying...
frenchfrog40
PostPosted: Wed Jan 23, 2013 7:10 am Up
iv had no trouble with my ones, i didnt use the little metal clip things they come with.
Iv had:
LiamGTi180
PostPosted: Wed Jan 23, 2013 7:24 am Up
I haven't had any problems with mine. If they are fitted properly without damaging seals etc then I would look elsewhere for the cause.
DanT
PostPosted: Wed Jan 23, 2013 9:25 am Up
No issues with mine either, using the supplied clips!
hayes_ctfc
PostPosted: Wed Jan 23, 2013 10:18 am Up
Mine have been on the car for a while and haven't had a problem *Touch Wood*
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
