![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › 206rc clutch plate on standard gti possible |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Fri Jan 25, 2013 5:05 am |
as above
| | ![](images/spacer.gif) |
Posted: Fri Jan 25, 2013 6:07 am |
Its the same gearbox.
Posted: Fri Jan 25, 2013 6:37 am |
Why bother?
Posted: Fri Jan 25, 2013 8:24 am |
sorry for asking still new to 2.0, i heartd thre is 2 type clutch 4 spring and 2 spring type
| ![](themes/base/images/forums/otr.gif) |
