Latest: Beduff1977
Overall: 17134
Online Now [484]:
Visitors: 483
Today: 149256
Total: 108965002
Forums › The Car › 206 Talk › Fog Lights
Fog Lights
Simmo
PostPosted: Fri Jan 25, 2013 7:44 am Up
Sorry wasn't sure which forum to post this in. Has anybody ever tried replacing there non fogged light bumper with one that does have fog lights? Just curious if this was possible or not as i couldn't find it on any other forum
Cheers
Ryan
1.1 silver style www.206info.co.uk/Foru...52484.html
iainlovatt
PostPosted: Fri Jan 25, 2013 8:27 am Up
Yep i did with my 1.1. Dead simple, just get the loom off ebay.
(My Garage)
PostPosted: Fri Jan 25, 2013 8:31 am Up
a quick search found this
Simmo
PostPosted: Fri Jan 25, 2013 9:30 am Up
Could you link me one off eBay, would be very grateful, I either aren't typing the right thing in or I'm just completely useless haha
PostPosted: Fri Jan 25, 2013 10:21 am Up
Front fog lights are pretty useless anyway, just not worth the hassle.
Be nice if manufacturers stopped fitting the dam things.
iainlovatt
PostPosted: Fri Jan 25, 2013 1:12 pm Up
clicky
(My Garage)
Domo
PostPosted: Fri Jan 25, 2013 11:47 pm Up
i have a loom and i have fog light bumper but the cables aint connected to anything at the back of the lights. what should i do? and dont say connect them. i mean how. cheers
gazza82
PostPosted: Sat Jan 26, 2013 4:12 am Up
You may find the connecting cables tucked away under/behind the headlights ... but that would depend on whether the loom was fitted with them at the factory. Even if you do, you'll probably find you column stalk doesn't have a front fog setting only a rear one!
For later cars (multiplex) you will probably also need the BSI setting up.
PS DON'T be tempted to wire them into the side or headlight circuits as that would make them illegal. You can only use them in poor visibility eg fog, falling snow, etc ... not like some muppets and just 'because it's raining a bit! Rolling Eyes
iainlovatt
PostPosted: Sat Jan 26, 2013 4:24 am Up
Could wire them into high beam,, always the best and easiest way!
(My Garage)
PostPosted: Sat Jan 26, 2013 4:42 am Up
But completely pointless because fog lights do nothing to help in a situation when high beam is needed!
iainlovatt
PostPosted: Sat Jan 26, 2013 5:08 am Up
difference of opinion there! I think they would make a slight bit of difference, and its easier to have people wire them up to high beam than put a full relay circuit in and talk them through it. Sad
(My Garage)
PostPosted: Sat Jan 26, 2013 5:28 am Up
Go down a dark country lane and just put your side lights on. Then put your fog lights on and they light up absolutley nothing of any use.
All they light up is a small amount of grass verge 4 metres in front of the car. So for people driving over 30mph they aren't of use at all - despite what they claim.
PostPosted: Sat Jan 26, 2013 6:22 am Up
What He Said
But they do make you look cool cruising round McDonald's carpark Laughing
Front foglamps are bad enough but now on newer stuff the w**ky corning lights are even worse Twisted Evil
gazza82
PostPosted: Wed Jan 30, 2013 5:53 pm Up
Also illegal unless it's foggy!! Don't forget our boys in blue are having budgets cut so where do you think they will look to make up the difference ...
