Latest: Worthy967
Overall: 17143
Online Now [356]:
Visitors: 355
Today: 38093
Total: 114463445
Forums › The Car › 206 Problems › Runnin problems
Runnin problems
Deano
PostPosted: Mon Jan 28, 2013 4:53 pm Up
Hi having problems with 206 1.6 xsi y reg the car starts but has no power does not rev and then stalls also the middle plug into the ecu a couple of. Wires were burned and melted together which we have cut back and rewired but still the same problem any ideas would be much appreciated thanks
meas14
PostPosted: Mon Jan 28, 2013 6:42 pm Up
Could be a coil pack issue... Mine went the other week, same symptoms, but i had engine management light come on and fault codes etc
Pug 206 GTI and Classic Mini Mayfair Owner
PostPosted: Tue Jan 29, 2013 8:42 am Up
Put it on a fault code reader. The burnt wires may have destroyed your ECU when they shorted.
Deano
PostPosted: Tue Jan 29, 2013 12:09 pm Up
If they has frazzled the ecu would it just not start at all sometimes it starts and runs fine for 5 mins but now it just starts n no power
PostPosted: Fri Feb 01, 2013 3:04 pm Up
It depends how badly fried it is. Also is there damage or a failed component elsewhere? If you have had an electrical problem that has melted wires in electrical terms that is a serious fault. You could have damaged oher components.
