Latest: Puggingalong
Overall: 17129
Online Now [149]:
Visitors: 148
Today: 82872
Total: 101290011
Forums › The Car › 206 Problems › rocker cover gaskets off 180 same as GTi 138?
iainlovatt
PostPosted: Wed Feb 06, 2013 8:20 am Up
Right so i have bought the GTi 180 engine cover, however it simple doesnt fit and im not willing to drill into it. So last night i bought a rocker cover off a 180. My question is will this fit 100% and cause no issue with my engine. From what i have read they are a straight swap however im not confident,
(My Garage)
Big_Rich180
PostPosted: Wed Feb 06, 2013 9:15 am Up
Wouldn't there be an extra hole in the 180 cover for the VVT sensor? (Not sure tbh just a long shot.)
iainlovatt
PostPosted: Wed Feb 06, 2013 9:55 am Up
Not if i shove a cloth in it, Smile
(My Garage)
Big_Rich180
PostPosted: Wed Feb 06, 2013 10:01 am Up
You'd be amazed at all the problems a cloth in the hole can sort.
iainlovatt
PostPosted: Wed Feb 06, 2013 10:12 am Up
Lol i bet! haha Making the assumption were still talking about cars! Rolling Eyes
(My Garage)
Big_Rich180
PostPosted: Wed Feb 06, 2013 10:23 am Up
Mmmm may be Laughing
Uz
PostPosted: Wed Feb 06, 2013 11:28 am Up
Might be able to make a blanking plate of some sort for the VVT as it won't be in use. Certainly worth a try if you've picked the parts up cheap enough.
PostPosted: Wed Feb 06, 2013 11:42 am Up
VVT has nothing to do with the rocker covers. Rear cover is the same and the front cover is too.
Camshaft sensor on a 180 sits in the side of the head so goes nowhere near the rocker cover.
SAB206
PostPosted: Wed Feb 06, 2013 12:06 pm Up
As Edward said, I've changed a few and they're the same.
www.sab-graphics.com
I AM SYDLEXIC!
Lex206
PostPosted: Wed Feb 06, 2013 12:57 pm Up
think there are 2 different types of rockercovers.
your planning to put the 180 engine cover on your gti i presume?
im planning to do the same just quite havent got there yet.
someone told me on here a long time ago that you need the rockercovers from an early 180 car?
you obviously need a rockercover that fits your gaskets.
say again..i THINK there are 2 different types of gaskets
Megane 225 RS
iainlovatt
PostPosted: Sun Feb 10, 2013 3:42 pm Up
My gti rocker covers were the same as the 180 rocker covers! After moving few cables I Managed to get 3 secure plastic bolts to hold cover down. Job complete.
(My Garage)
Lex206
PostPosted: Tue Feb 12, 2013 8:42 am Up
i had a go at it today,turns out i THINK my 180 cover will fit my gti as well.
but i only had one plug that came with it,so have to go to the dealer to get more of them.
but now is the question..get it colour coded or carbon dipped..
Megane 225 RS
iainlovatt
PostPosted: Wed Feb 13, 2013 2:11 am Up
U may have to alter a few. Things around engine block ie move couple of wires a couple of mm but it will fit, Smile
(My Garage)
