Latest: Beduff1977
Overall: 17134
Online Now [208]:
Visitors: 207
Today: 54645
Total: 107160035
Forums › The Car › 206 Problems › 138 GTI Starting Issue - Any Ideas?
crocdino
PostPosted: Mon Feb 04, 2013 10:57 am Up
Never had a problem in over 3 years, had a new battery a year or so ago.
My OH just rang leaving work and it wouldn't start.
Key turns, ignition came on, lights and radio work etc etc.. but then wouldn't turn over. Didn't even try, just nothing.
Took key out.. tried again and it started straight off.
Nothing flashed up on the display, either. 53 reg facelift. Any ideas?
GTI 138 facelift - Runabout
335d M Sport - Cruiser
PostPosted: Mon Feb 04, 2013 12:52 pm Up
It's only done it once? I wouldn't worry about it. If it does it again, remove the key, lock and unlock the doors and try again.
PostPosted: Mon Feb 04, 2013 12:56 pm Up
What year?
crocdino
PostPosted: Mon Feb 04, 2013 6:55 pm Up
2003 53 - facelift
Cheers
crocdino
PostPosted: Tue Feb 05, 2013 2:31 am Up
Started all ok this morning
clark_me_dead
PostPosted: Sun Feb 24, 2013 5:29 am Up
Just thought I'd continue with this thread rather than starting a new one.
I've got a 2005 GTi, started to notice that its taking a little longer to start up from a cold start..
Whenever I start the car, I usually turn the key to 'ignition ON ' let the fuel pump prime for 5 secs than fire her up.
But even with that its struggling now.
Could me coil packs or battery be on the way out?
Peugeot 206 GTi 05
spike_202
PostPosted: Sun Feb 24, 2013 7:37 am Up
get the battery tested, most garages will do it for free mate that would be my 1st option.
**spike's project**
TEAM:+200bhp
crocdino
PostPosted: Sun Feb 24, 2013 1:37 pm Up
I've still not had this starting problem happen again - forgotten about it now.
Is it struggling to turn over? - Battery?
Or is it struggling to catch? - Fuel pressure? etc
Someone with a bit more general knowledge should be able to help.
clark_me_dead
PostPosted: Sun Feb 24, 2013 2:28 pm Up
Thanks guys! I have a feeling it's battery, I'll get it checked out.
Peugeot 206 GTi 05
