Latest: Stu-mill
Overall: 17131
Online Now [516]:
Visitors: 515
Today: 5981
Total: 104691632
Forums › The Car › 206 Problems › Car spluttering on start-up
jamiegti
PostPosted: Mon Mar 11, 2013 3:47 am Up
Hi, i have a peugeot 206 gti (2000), it has always run perfect but the other day when i started it up the car started to splutter bad on tick over and when i reved it spluttered even more and loses power until i put my foot down on the pedal and it would rev like normal. After 30 or 40 seconds of running the yellow engine management comes on and the car seems to run fine.. the light stays on though until you turn the car off and back on again, but everytime you turn the car on the same happens.. Any ideas?
chief93
PostPosted: Wed Mar 13, 2013 5:38 pm Up
My old one did it a couple of times. purely because it was -5.
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
Resist
PostPosted: Thu Mar 14, 2013 5:28 am Up
I had a similar problem on my 1.4. I know they're different engines, but could be a similar problem.
The only difference is that my engine light didn't come on.
I cleaned my idle control valve and also replaced the MAP sensor, and the problem has stopped.
Hope this helps.
www.soundcloud.com/resist
jamiegti
PostPosted: Sat Mar 16, 2013 8:06 am Up
Thanks for response, i have taken the car into the peugeot dealer to get a test done and they said that my oxygen sensor needed changing.. Today i have disconnected it and my car seams to be running fine, i am not going to drive my car like it is because i have been told it could break the CAT! While looking for this sensor i got told there was 2 of them(one before the CAT and one after it) i can only find 1 :S is it possible that the oxygen sensor after the CAT has been taken out as my exaust system is not the standard one? Thanks
Predator_aod
PostPosted: Sat Mar 16, 2013 12:45 pm Up
I'm no where near an expert but it have you checked the Catalyst Converter? If it's blocked you'll know because you won't be able to do more that 40mph or you'll feel major power loss when driving.
A passion for cars.
Jeffers
PostPosted: Sun Mar 17, 2013 7:12 pm Up
Is it like a missfire ? Mine did this when cold. I put it down to a dodgy battery not liking the cold
