Latest: Stu-mill
Overall: 17131
Online Now [314]:
Visitors: 313
Today: 33819
Total: 104842669
Forums › The Car › 206 Talk › GTi 138 Engine Question
PostPosted: Sat Mar 23, 2013 4:56 am Up
I have a slight oil leak on my GTi, and after looking underneath, I can see a black pipe what runs under the exhaust manifold, to somewhere near the cambelt cover end. There is oil all over this, so I am looking for any info/pics as to what this is.
Ill upload some pics now, there isn't much room to investigate properly.
PostPosted: Sat Mar 23, 2013 4:59 am Up
PostPosted: Sat Mar 23, 2013 5:12 am Up
That's a coolant pipe from water pump to thermostat housing. Oil on that is likely to be from the back of the rocker cover.
Could also be from a seal behind the cambelt cover. More likely to be the rocker cover though.
PostPosted: Sat Mar 23, 2013 9:34 am Up
Rocker cover below and the back of the engine feel clean of oil. When its dry ill take the rocker covers off and check for a leak. Must be running from the top for that pipe to be wet with oil.
Im going to change my timing belt in the summer, so I might remove my engine completely. Im sure my manifold is blowing, so might be easier to remove the whole engine and do it on an engine stand.
