Latest: Puggingalong
Overall: 17129
Online Now [145]:
Visitors: 144
Today: 5178
Total: 101627205
Forums › The Car › 206 Talk › AUX Belt Rollers
AUX Belt Rollers
Zack
PostPosted: Fri Mar 22, 2013 6:44 am Up
Is this roller www.ebay.co.uk/itm/400...1423.l2649
Shame as this www.ebay.co.uk/itm/130...1423.l2649
For get a bout the Tensioner Pulley dont need that.
What am trying to find out is if i buy two of the top ones will that work?
cheers
Zack
PostPosted: Fri Mar 22, 2013 7:00 am Up
There different sizes
PostPosted: Fri Mar 22, 2013 9:35 am Up
One is the tensioner which is needed. One is the roller which isn't needed if you bin the air conditioning! Both pulleys are different to each other so can't be swapped.
PostPosted: Fri Mar 22, 2013 9:41 am Up
if u want the part number for these runners,send me your VIN,and it's better to get the original ones
Zack
PostPosted: Tue Mar 26, 2013 1:55 pm Up
All sorted now no noise no more funny looks
PostPosted: Sun Mar 31, 2013 4:09 pm Up
good to know,what did you do?
Zack
PostPosted: Sun Mar 31, 2013 5:25 pm Up
Change the belt and roller no noise now thank god
PostPosted: Mon Apr 01, 2013 1:08 pm Up
Thumbs Up
