Latest: tebas93089
Overall: 17179
Online Now [369]:
Visitors: 368
Today: 2031
Total: 137774440
Forums › The Car › 206 Problems › Amp problem again
Amp problem again
Smokey206
PostPosted: Fri Apr 05, 2013 11:12 am Up
Hi basically took my sub and amp out my car yesterday and went to put back in today I connected all the wires and even without the keys in the car the fuse blows straightaway I think I may have mixed a wire round the wrong way but not sure and never done this before and was already in car when I brought it Crying or Very sad
jimgemlill
PostPosted: Fri Apr 05, 2013 11:30 am Up
Stick another fuse in. You could do with checking/testing the wiring for any damage. The ice stupid questions section has a car audio basics guide.
Find an amp wiring guide on here and make sure its right.
Nimrods bought to refurb
Smokey206
PostPosted: Fri Apr 05, 2013 11:53 am Up
I stuck another fuse in and it blow straight away
mehoolkmusic
PostPosted: Fri Apr 05, 2013 12:10 pm Up
Check you connections, Ground ETC Check you power cable it may be cut somewhere, Touching the metal making the fuse blow etc...
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
PostPosted: Fri Apr 05, 2013 12:20 pm Up
Well you have a short circuit somewhere then.
