Online Now [564]:
Visitors: 563
Today: 92436
Total: 105819043
Forums › The Car › 206 Problems › GTi 180 clutch question. Urgent
uttz
PostPosted: Sat Apr 20, 2013 6:55 pm Up
FIRST thing, I'm not in the UK I'm in Trinidad and Tobago.
Secondly my 206 Gti 180 is the only one on the Island.
So here goes:
What is the Part No. of a 206 GTi 180 Clutch kit... been getting a million different ones for pug themselves and when referenced say 228mm 18 splines.
also i saw that the black diamond clutch kit specs say it is 228mm and 23 splines while the s16 is 18 splines.. is this true of an error on part of blackdiamond/europerformance.co.uk? HOW MANY SPLINES ARE THERE?
well my clutch is slipping and in need of one soon so is the clutch kit the same as 406/407/etc so this is needed urgently
thank u all
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
uttz
PostPosted: Sat Apr 20, 2013 7:08 pm Up
not 23 meant 21 splines.... a valeo part number would be great also thanks
PostPosted: Sun Apr 21, 2013 2:10 am Up
Like anything that could vary in size, shape, spec etc it's best to remove your old one and measure everything. Inconvenient I know but it's the best way to make sure.
uttz
PostPosted: Sun Apr 21, 2013 7:36 am Up
meh been dreading this Sad took it down once before, for the rear engine seal should have taken measurements then... been researching some more... the newest part number is 2051t9 for those in the need to know
uttz
PostPosted: Mon Apr 22, 2013 5:53 pm Up
so checked the part numbers:
2051G6, 205268 2052K1 and appear they are all 18 tooth clutch kits that work on the 407/206 GTi/ 206 GT180/307 2.0. still dont understand why the aftermarket clutches are listed as 21 spline and cost more for a 180 than gti...
what recommendations you guys have with respect to a clutch kit for the 180 or should just stick to peugeot OE product. was looking at fast road as i do auto-x and other carpark based racing events and very spirited driving (our roads here are like tarmac rally stages)
PostPosted: Tue Apr 23, 2013 5:03 am Up
Go to Valeo on-line parts gatalogue and you will find a cross-ref of your exact Peugeot code to the Valeo kit code.
That way you'll get correct original OEM parts at a much lower cost.
