Latest: S2cgm
Overall: 17178
Online Now [391]:
Visitors: 390
Today: 75417
Total: 137426370
Forums › The Car › 206 Problems › Diagnostic Results
Diagnostic Results
IceWhyte
PostPosted: Mon Apr 08, 2013 11:02 am Up
I ordered one from eBay. Hopefully I manage to fit it easy.
Deckchair5
PostPosted: Mon Apr 08, 2013 12:08 pm Up
As easy as changing a spark plug really
Make sure to reset the fault codes afterwards otherwise it may go on ignoring the flagged sensor, clearing the codes will also reset the fuel trims and allow the ECU to readjust again to using the new sensor
IceWhyte
PostPosted: Wed Apr 10, 2013 11:55 am Up
Well I got it and fitted it today but there is no change, error code is still there which was expected but the car still hangs on to the revs so the fuel problem is still there. Just hope clearing the code will fix it.
Worrying though, the sensor was undone by hand. I was expecting it to be ultra tight as someone told me that they sometimes have to be burnt off. So guess the previous owner must of been in at it.
Deckchair5
PostPosted: Wed Apr 10, 2013 2:01 pm Up
Yes, as stated before, you'll need to reset the fault codes otherwise it just assumes the bad sensor is still there. It'll take a little while to settle in with the best settings to the new sensor too
You're right to be concerned that the sensor was only in hand tight. It certainly suggests someone careless was messing about with it
IceWhyte
PostPosted: Tue Apr 16, 2013 11:47 am Up
Thanks very much for everyone's help.
I bought a diagnostic tool for £10 of Amazon, just plugged it in, hit reset and bye bye "Anti Pollution Fault".
Thanks again.
IceWhyte
PostPosted: Fri Apr 19, 2013 1:32 pm Up
Well the fault is back. I am stumped Sad
xdoddyx
PostPosted: Fri Apr 19, 2013 2:11 pm Up
Is the problem still there? or is it just the Anti pollution light.
Moonstone HDI
PostPosted: Fri Apr 19, 2013 3:02 pm Up
If it's a 1.4 TU3 and the revs also hang, check intake/exhaust valve tappets clearance.
It would also explain lack of power.
Deckchair5
PostPosted: Sat Apr 20, 2013 3:08 am Up
The anti pollution warning is a diagnosis over a period of time so by just clearing the fault code then it's just a matter of time before reappears if the fault is still there
First step is to read your present fault codes. We presume your pre cat O2 sensor fault is now fixed so that one should not be reappearing. On a better scan tool you may see freeze frame data which will give more of a clue as to why APF is being triggered.
Ideally, with better scan equipment, you want to see the output traces from your pre cat and post cat sensors to compare them and then you can see what the OBD is seeing and why the APF is on. The OBD wants to see frequent switching from the pre cat and fairly flat trace from the post cat sensor at steady rpm. If the post cat mirrors the pre cat then it shows the cat isn't doing anything
A misfire can also trigger an APF as the O2 sensors will be affected by the excess fuel so look at the fault codes and post them up
IceWhyte
PostPosted: Sun Apr 21, 2013 11:44 am Up
It's a 1.4 Quicksilver, the revs were hanging before I changed the o2 sensor.
That's strange because I tried resetting the codes a few days prior to changing the sensor and it returned straight away, however after I changed the sensor and reset codes the faut was gone. I will plug it in again tonight and see what it says.
IceWhyte
PostPosted: Sun Apr 21, 2013 12:37 pm Up
I just checked, I am getting the p0353 and p0135. First one is something to do with an ignition coil and the second one appears to be the heated oxygen sensor again.
Deckchair5
PostPosted: Sun Apr 21, 2013 4:22 pm Up
P0135 O2 sensor heater circuit malfunction
This is different to fault you had before as this relates purely to the O2 heater circuit and not the signal circuit
I'd back probe the O2 sensor connector, you can use a metal pin, check for power and reference earth at the O2 sensor heater wires,they'll be the two wires that are the same colour. Check the resistance thru the sensor across the two heater wires with sensor disconnected, should be just a few ohms
P0353 is detected misfiring so do you notice misfiring? Freeze frame data could be useful to help you detect when it's occuring
PostPosted: Mon Apr 22, 2013 2:53 am Up
Misfiring (v.slight and rare), lack of power, poor fuel economy, revs hang, λ-related DTC all ring bells of valve adjustment needed to me..
Also note I've seen heater circuit fault come-up on the 206 only to find that it's 100% working fine in all respects (full tests from ECU continuity, Ω of heater resistor etc) and it was indeed to do with running of the engine by the ECU.
How many miles on the clock?
Deckchair5
PostPosted: Mon Apr 22, 2013 11:57 am Up
I'd still check for power and earth at the O2 heater circuit as you can have continuity and heater element resistance be correct but without power and earth then no current is flowing. If the current is less than 0.1amp then it triggers the P0135 and as someone has been playing about with it then it could easily be just a simple blown fuse.
If the pre cat O2 sensor isn't getting up to temp then the emissions go to pot and you get the APF
PostPosted: Mon Apr 22, 2013 1:56 pm Up
Good points and yes check, but you can have 100% correct λ-sensor opperation with proper voltage across the heater (+ve supplied by the relay beneath the ECU) correct current flow etc and still get the heater circuit DTC.
This ofcourse is not meant to be.
Page 2 of 3
