Latest: Beduff1977
Overall: 17134
Online Now [673]:
Visitors: 672
Today: 16969
Total: 108159889
Forums › The Car › 206 Problems › engine oil
engine oil
mikeyo
PostPosted: Mon Apr 22, 2013 12:44 pm Up
Hi im new to this forum so forgive me if im in the wrong area but im having trouble finding out which oil i should be using for my pug206 1.1lx 02 plate Halfords returns nothing on search and other websites range from 0/40,5/40,10/40 surely all these cannot be used
any help would be much appreciated.
Mike
PostPosted: Mon Apr 22, 2013 12:48 pm Up
Pictures are missing, but this thread will help
www.206info.co.uk/Foru...t=548.html
mikeyo
PostPosted: Mon Apr 22, 2013 1:37 pm Up
onthanks for that,by the way does anyone have an oil leak of a bout 2/3 drips on the driveway a night,wondering if its common problem,not to fussed as i can keep topped up just always reassuring to know its common.
DREWDEN
PostPosted: Mon Apr 22, 2013 2:13 pm Up
How do you know its not coming from your gearbox, I would be fussed if it were, (it only holds 3 and half pints).
Could be escapeing whilst driving as well.
Check to see where its coming from if i were you.
206 2ltr Hdi glx 53 plate
PostPosted: Mon Apr 22, 2013 6:38 pm Up
More than likely the head gasket quite common on the TU engines.
bikesforme
PostPosted: Tue Apr 23, 2013 3:06 am Up
I had slight oil drips coming down my drivers side, i replaced rocker gasket , sumptuous gasket , camshaft oil seal, crankshaft oil seal. In the end it was the headgasket , now all done
Its a easy job to do and good chance to replace cam belt, water pump and new coolant. I brought a second hand head and cleaned that all up and rebuilt that has i spent extra time porting it to match my gaskets and still used my car for work.
