Latest: tbafonso
Overall: 17130
Online Now [87]:
Visitors: 86
Today: 8930
Total: 102083268
Forums › The Car › 206 Talk › Rear Dampers
Rear Dampers
Zack
PostPosted: Wed May 08, 2013 1:30 pm Up
Would these 306 dampers fit?
Cheers
www.ebay.co.uk/itm/200...1423.l2649
usher
PostPosted: Wed May 08, 2013 1:37 pm Up
even if they did dont expect any difference
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Wed May 08, 2013 1:44 pm Up
What you mean? they will make my ride harder wont they?
PostPosted: Wed May 08, 2013 2:08 pm Up
Why not just go buy a proper set of bilstine dampers designed for the 206?
Zack
PostPosted: Wed May 08, 2013 2:28 pm Up
are they adjustable do you have a link?
Cheers
usher
PostPosted: Wed May 08, 2013 4:07 pm Up
they might slightly but the torsion bars set how stiff it is
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Wed May 08, 2013 4:10 pm Up
To make it stiff you need stiff dampers found some now any way 110 delivered me gaz ones Smile
Uz
PostPosted: Wed May 08, 2013 7:34 pm Up
LOL
Zack
PostPosted: Thu May 09, 2013 1:22 am Up
Uz wrote:
LOL
What
Uz
PostPosted: Thu May 09, 2013 1:54 am Up
Zack wrote:
Uz wrote:
LOL
What
So, let me get this straight... if I had a 1.1 with 17mm torsion bars and stuck just a set of SPAX bone breaking shocks on the rear end, my suspension will be stiff..? No itll still flop around like a limp d**k.
To stiffen suspension you have to do spring and shocks / torsion bars and shocks not one or the other.
Zack
PostPosted: Thu May 09, 2013 2:02 am Up
What the point in adjustable dampers then? If they don't do anything.
PostPosted: Thu May 09, 2013 2:17 am Up
Try and learn what a shock absorber does first, and then you might start understanding the workings of the suspension system.
Zack
PostPosted: Thu May 09, 2013 2:38 am Up
Well i have ordered them now so ill just fit them
Zack
PostPosted: Thu May 09, 2013 2:54 am Up
What size bar would you say is best?
www.bueni.co.uk/car/20...eb_6137050
Cheers
PostPosted: Thu May 09, 2013 2:59 am Up
Fit uprated dampers to a car with standard torsion bars. Put 100kg in it. The suspension drop will be the same as before.
Put the same load on a car with uprated torsion bars and it won't drop as far.
The clue to what dampers do is in their name. They dampen the energy in the torsion bars. So they slow down the suspension movement.
