Latest: ArtistKS
Overall: 17145
Online Now [49]:
Visitors: 48
Today: 159
Total: 115961972
Forums › The Car › 206 Talk › Changing steering wheel
Speighty
PostPosted: Fri May 17, 2013 6:28 am Up
I'm looking to change the steering wheel on my 206 51 plate.
Just wondering if the 206 cc red and black wheel would fit and could I use y existing airbag.
Cheers.
iainlovatt
PostPosted: Fri May 17, 2013 6:44 am Up
what year 206 is it coming off?
(My Garage)
PostPosted: Fri May 17, 2013 6:54 am Up
Depending if your car is preplexed or plexed will depend on the wheel that you fit. The air bag should be a straight swap as long as you get the right steering wheel.
Speighty
PostPosted: Fri May 17, 2013 8:05 am Up
Coming of a 2002 206 cc.
Not sure if my car pre plex or multiplex.
I know there is a thread explaining the difference but the photos are not available.
This is the wheel
www.ebay.co.uk/itm/261...26_rdc%3D1
PostPosted: Fri May 17, 2013 9:30 am Up
This is the wheel
You need to find out what type your car is BEFORE you spend money on a replacement steering wheel.
The 2 different types of steering wheel fitments on the 206 are 100% NOT interchangeable.
Speighty
PostPosted: Fri May 17, 2013 10:36 am Up
Looks like my car is mulitplex as I have a ppt40 mfd, I checked the guide and that's what it says, is that correct.
I will find out what car the other one came off.
PostPosted: Fri May 17, 2013 10:42 am Up
PPT 40 display connector plug = multiplex.
The Ebay linked wheel is multiplex.
PostPosted: Fri May 17, 2013 10:43 am Up
If the other car is 2002 then that's multiplexed.
If you have the big squareish radio control to the right of the steering wheel then you have a multiplexed. If it's a round one then it's pre plexed.
Once the staffing is sorted, I'm sure that the links to the pictures will be replaced so that people can see them.
Speighty
PostPosted: Fri May 17, 2013 12:27 pm Up
This is the mfd i have
www.ebay.co.uk/itm/Peu...4170f23e36
This is the radio control that i have
performancepeugeot.com...ucts_id=53
Thsi is the model number he gave for the mfd that was in the 206cc
www.ebay.co.uk/itm/peu...3cd1992cba
Speighty
PostPosted: Sat May 18, 2013 3:23 pm Up
Can anyone confirm the above for me, cheers.
tsotd
PostPosted: Sat May 18, 2013 3:34 pm Up
all looks fine to me
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
