Posted: Mon May 20, 2013 11:50 am |
Got to change the middle vents on my 51 plate how you get them off
Posted: Mon May 20, 2013 12:27 pm |
Remove the the black plastic clips which are just above the bonnet catch, then unscrew the bolts x2 (1 either side) of the badge itself then pull the edges of the grille where they meet the front wings
Posted: Mon May 20, 2013 12:41 pm |
I meant the middle vents in side the car above the CD player
Posted: Mon May 20, 2013 12:54 pm |
millhouse30 wrote: |
I meant the middle vents in side the car above the CD player |
Wiggle & pull
Posted: Mon May 20, 2013 1:21 pm |
That it
Posted: Mon May 20, 2013 1:37 pm |
That it |
Yep, simple as that
Posted: Mon May 20, 2013 2:06 pm |
Push it down towards the floor, then pull the top bit.
| I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport | |
Posted: Mon May 20, 2013 2:17 pm |
Hawkers wrote: |
Push it down towards the floor, then pull the top bit. |
or pull it up (from the bottom) and grab the bottom bit & pull towards you. Either way will do - it's easy to remove & replace.
