Latest: tbafonso
Overall: 17130
Online Now [617]:
Visitors: 616
Today: 127138
Total: 102703040
Forums › The Car › 206 Problems › Window electrics advice
Tolkienfan001
PostPosted: Mon May 20, 2013 2:30 pm Up
Trade Rating: +13
Hi
I am looking for some advice from the electrically minded people on here.
I have just tried to fit the electric window control with the folding mirror switch and the auto drivers window control.
My current control has the two manual window switches and the mirror control without folding mirrors.
When I re connected the battery, the negative terminal sparked and it blew fuse number 12.
I have removed the new control and put my old one back in. I have also put fuse 9 (rear electric windows, which i do not have) in place of fuse 12.
Can you please tell me what I did wrong? Surely this control should work?
Am I ok to remove the fuse connect everything up and then put the fuse back in, or is there something wrong with the control?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Mon May 20, 2013 2:36 pm Up
Well your old switch didn't have the Auto Feat.,so every time you plug it in,the fuse will be burned,to fix this,you need to use the PP2000,and make the driver's window an Auto one in the configurations,and everything will work good Very Happy
Tolkienfan001
PostPosted: Mon May 20, 2013 2:44 pm Up
Trade Rating: +13
Ok that makes sense I guess. This will have to wait until I can afford pp2000.
So when I do it next time. Should I disconnect the battery, remove the old switch. Connect the battery again. Change the setting. Disconnect the battery. Add the new switch and then re connect the battery again?
2005 1.4 16v Sport
PostPosted: Mon May 20, 2013 2:55 pm Up
No need to disconnect the battery,just use the PP2000,and make sure it's activated,then plug the new switch,and all will be fine Smile
Cheers Smile
Tolkienfan001
PostPosted: Mon May 20, 2013 2:56 pm Up
Trade Rating: +13
Thank you buddy, appreciate the help and education Wink
2005 1.4 16v Sport
PostPosted: Mon May 20, 2013 4:33 pm Up
Can't see why that switch would blow the fuse, don't think changing the setting in pp2000 will change it. Did it pop before you tried the switch?
Tolkienfan001
PostPosted: Mon May 20, 2013 4:49 pm Up
Trade Rating: +13
Yea as soon as I connected the battery negative terminal. It arced as I touched the connector to the terminal.
2005 1.4 16v Sport
PostPosted: Mon May 20, 2013 4:54 pm Up
Known issue with multiplex 206 when you try & change a poverty spec switch to auto one shot.
Im not sure if its the actual cabin wiring loom or BSI unit that's different.
One shot unit is part of the switch, door loom & window motor are the same.
Tolkienfan001
PostPosted: Mon May 20, 2013 4:57 pm Up
Trade Rating: +13
So unless I change it all don't bother?
2005 1.4 16v Sport
PostPosted: Mon May 20, 2013 5:10 pm Up
No idea, never really looked in to it in depth.
The fuse blowing straight away when the auto switch was connected says a +12 feed is short circuited to earth so its either the cabin wiring loom is different OR its something inside the actual BSI unit.
It will be break out the wiring diagrams & study time.
Tolkienfan001
PostPosted: Mon May 20, 2013 5:12 pm Up
Trade Rating: +13
Ok thank you
2005 1.4 16v Sport
