Posted: Sat Apr 07, 2012 10:19 am |
Was just out in my car and been driving like a nun for past day or so. Joined a motorway slip road put the pedal down and not much happened. It was seriously under powered. Got off the motorway and pulled over, restarted the engine and all was well again Anybody else had this issue as couldn't find anything on here or google. Is anything on its way out or was it just throwing a wobbler. Its under warranty for another 2 1/2 months so if something needs fixing will get it done.
Posted: Sat Apr 07, 2012 10:22 am |
might be your vvt solenoid, far as i know it just needs removing and cleaning with carb cleaner, 1 sign is that the cars feels like a 1.1
Posted: Sat Apr 07, 2012 10:24 am |
| Dan- wrote: |
| might be your vvt solenoid, far as i know it just needs removing and cleaning with carb cleaner, 1 sign is that the cars feels like a 1.1 |
Yeah definately but would say more like a 1.4 as it moved a little. Any idea where the vvt solenoid is? have some carb cleaner in the garage from my old motorbike
Posted: Sat Apr 07, 2012 10:25 am |
will have a quick look for ya I've seen it somewhere on here
Posted: Sat Apr 07, 2012 10:30 am |
i194.photobucket.com/a...mabove.jpg
the vvti solenoid is the sensor on the right hand side of the coil pack, (looking at that pic) its actually on the left looking at the engine, its held in with a allen key and just pulls out, but be carful not to drop when its out as its very delicate and rather pricey i think
Posted: Sat Apr 07, 2012 10:32 am |
| Dan- wrote: |
http://i194.photobucket.com/albums/z44/kieronpunto/180enginefromabove.jpg
the vvti solenoid is the sensor on the right hand side of the coil pack, (looking at that pic) its actually on the left looking at the engine, its held in with a allen key and just pulls out, but be carful not to drop when its out as its very delicate and rather pricey i think |
Thanks for the help appreciate it will give it a clean
Posted: Sat Apr 07, 2012 11:02 am |
no worries, also while your at it might swell clean the mass air meter, it only bolts into the throttle body, 10mm socket i think, access is very tight and you might drop the bolt but its just falls out under the car
Posted: Thu Apr 12, 2012 1:13 pm |
| Dan- wrote: |
no worries, also while your at it might swell clean the mass air meter, it only bolts into the throttle body, 10mm socket i think, access is very tight and you might drop the bolt but its just falls out under the car  |
Think my carb cleaner has turned up as turns out I didnt have any so ordered some off ebay Will give this a go at weekend hopefully will also sort out why it feels underpowered low down in the rev range. I know its high revving my my mums 1.4 206 has more urgency low down in second gear
Posted: Thu Apr 12, 2012 4:23 pm |
Had a similar issue wih my 138 pal
Loss of power and warnin light. After replacing ALL the sensors on the engine including icv it turned out to be the cat had collapsed!!!
Just another thought pal. Worth checking!!
Cheers
Dave
Posted: Sun Apr 15, 2012 3:55 am |
Gave it a good blast with the carb cleaner and seems to drive smoother and now picks up quicker lower in the revs. Just need to find the ICV now so its not rough at idle.
Posted: Sun Apr 15, 2012 4:01 am |
hey at least your getting somewhere now and btw the 180 doesn't have a removable icv its an electronic throttle body so the ivc not cleanable/removable
Posted: Mon Apr 16, 2012 5:51 am |
Ah no problem, will try find the Mas air thingy and see if that does anything
Posted: Tue May 21, 2013 1:14 pm |
I know this is an old post. Mine had these symptoms this morning. I was going up the road then power just dropped off. I was just wondering if anyone had a guide to cleaning the VVTi solenoid?
Did the problem stay solved? Or is it worth getting a new one?
Thanks you in advance for your advice
Posted: Tue May 21, 2013 1:38 pm |
Posted: Tue May 21, 2013 2:01 pm |
| Jammie_1989 wrote: |
Ah no problem, will try find the Mas air thingy and see if that does anything  |
Hope you aren't still looking for it as there isn't one fitted!
