Latest: tbafonso
Overall: 17130
Online Now [197]:
Visitors: 196
Today: 48941
Total: 103410222
Forums › The Car › 206 Problems › The "Stop" Button
The "Stop" Button
T0BEZ
PostPosted: Thu May 30, 2013 6:01 pm Up
Okay, so basically my car is a 1.1 Peugeot look, Recently my car has started popping up with the stop button, and keep flashing, the hand brake light was on also, When my handbrake was fully released? Also, I started to brake and it started beeping at me again. Then it will randomly turn off? Is it telling me I need to replace something? My oil is fine, brake fluid fine also. Bit clueless really and it's bugging me.
Sig removed due to size
20Drift
PostPosted: Thu May 30, 2013 6:07 pm Up
What year, (Plexed or pre-plexed)?
If it's plexed, then try a BSI reboot, (detailed here: www.206info.co.uk/Foru...boot.html)
T0BEZ
PostPosted: Thu May 30, 2013 6:39 pm Up
It's an 02 Plate mate but also my handbrake is starting to become loose?
Tolkienfan001
PostPosted: Fri May 31, 2013 2:05 am Up
Trade Rating: +13
Sounds like an issue with the rear brakes? Drums I assume?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Fri May 31, 2013 3:57 am Up
Check the connection on the handbrake switch. It's possibly making a ghost contact. This would fool the car into thinking the handbrake was being put on. No idea if it would cause the beep, but it would certainly put the brake warning light on on the dash.
Hawkers
PostPosted: Sat Jun 01, 2013 2:33 pm Up
Central (STOP) warning light. Linked to the "engine oil pressure", "coolant temperature and low coolant level", "handbrake", "low brake fluid level" and "electronic brake force distribution system fault" warning lights.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
T0BEZ
PostPosted: Thu Jun 06, 2013 5:01 am Up
I topped my brake fluid up, and it hasn't came back on, Thank god haha Smile
