Online Now [217]:
Visitors: 216
Today: 65936
Total: 106043024
Forums › The Car › 206 Problems › Throttle body cleaned
Majid
PostPosted: Mon Jun 17, 2013 12:49 pm Up
Hi all
I have a peugeot 206 1.6i 16v petrol 2003
I cleaned my throttle body with carb cleaner sprayed the motor with electrical contact cleaner and into the engine breather pipe.
The car starts but the car don't pick up speed. Top speed 5mph
What could of caused this
Any help?
PostPosted: Mon Jun 17, 2013 1:18 pm Up
well you have check the acc. pedal cable if it's fitted right?,it's 2003 so i believe that yours is drive by cable and not by wire.
PostPosted: Mon Jun 17, 2013 1:23 pm Up
I thought all but the very earliest 2001 XSI's were FBW?
PostPosted: Mon Jun 17, 2013 1:29 pm Up
is't a NFU engine?
Majid
PostPosted: Mon Jun 17, 2013 1:48 pm Up
Update when I installed everything back I didn't attach the steeper motor to the throttle body
But iv got the revs now
But idle not settling
What u reckon should do?
Thanks guys for all your help really appreciate it
Peugeot 206, 1.6, 16 valve
2003
PostPosted: Tue Jun 18, 2013 4:50 pm Up
Sticking stepper motor?
Majid
PostPosted: Wed Jun 19, 2013 4:21 am Up
Solved erattic idle by following bsi reset procedure
2003
PostPosted: Wed Jun 19, 2013 5:33 am Up
Shocked
