Online Now [176]:
Visitors: 175
Today: 40600
Total: 105303978
Forums › The Car › 206 Problems › Revs
Revs
Neilsharon1990
PostPosted: Tue Jun 25, 2013 3:32 am Up
I've got a 1.4hdi 2002 when the engine reaches 3000 revs it losers power. I've had a local mechanic have a look he's tried different sensors but with no luck. He doesn't seem to know problem as anybody come across this before.
DREWDEN
PostPosted: Tue Jun 25, 2013 5:39 am Up
I would be tempted to look at the fuel system side of things.
filter, injectors, pump.
Any warning lights on dash at all.
206 2ltr Hdi glx 53 plate
Neilsharon1990
PostPosted: Tue Jun 25, 2013 7:57 am Up
The engine management light is on but he said it showed something about heater plugs but that would not be problem. One of the sensors he changed I was told was something to do with drive shaft but that did not cure it.
Lowiee
PostPosted: Tue Jun 25, 2013 8:21 am Up
sounds like the engine limiter to me have you checked that it has got one as its a diesel
eddie206
PostPosted: Tue Jun 25, 2013 9:31 am Up
U need the codes reading before you spend any more money.
PostPosted: Tue Jun 25, 2013 2:47 pm Up
I agree! What He Said
DREWDEN
PostPosted: Tue Jun 25, 2013 4:24 pm Up
Surely the mechanic must have code read it, before he messed around with swapping sensors.
Obvious first step for any mechanic i would have thought, or at least an electrician to test the sensors.
eddie206
PostPosted: Tue Jun 25, 2013 6:30 pm Up
Im guessin as he says local mechanic that he will work without the code reading stuff just doing it oldskool...
Neilsharon1990
PostPosted: Wed Jun 26, 2013 9:27 am Up
He code read it but he said it was something to do with heater plugs which he said wouldn't cause this problem
PostPosted: Wed Jun 26, 2013 10:04 am Up
Find someone that KNOWS what there doing & talking about Wink
