Online Now [131]:
Visitors: 130
Today: 5222
Total: 139079997
Forums › The Car › 206 Problems › 206 1.1 steering wheel vibration
crunchydaddy
PostPosted: Wed Jun 26, 2013 12:26 pm Up
Hi gang!
Have just bought a 2001 1.1 LX and have come across a couple of problems.
1. When I'm driving between 50-70, the steering wheel is vibrating a lot. I have heard that may be due to wheel balancing, so I have just had the front two wheels balanced but the problem still remains.
2. When in 5th gear, there seems to be like a high-pitch noise coming from the gearbox, not in any other gear, just 5th. I've had a lot of Peugeots and they all make the same noise but in 2nd or 3rd.
Any ideas most welcome. Very Happy
PostPosted: Wed Jun 26, 2013 3:13 pm Up
well for the first problem,you might have bad tires,or bad disks,and for the second problem,you have a faulty toothed gear,which is the 5th in your case.
