Latest: sparrowdclxvi
Overall: 17139
Online Now [70]:
Visitors: 69
Today: 30604
Total: 113270839
Forums › The Car › 206 Problems › Engine Blew Up :(
Engine Blew Up :(
Royceybaby
PostPosted: Wed Aug 07, 2013 5:14 pm Up
So my lovely 206 has died, cambelt came off and destroyed the engine.
Its at my local garage, it was going to have a new(used) engine put in, but they said they were mis quoted and that was too much.
It is now having an engine rebuild for £1500, BUT the garage is saying its waiting on two fundamental parts that can only be got from Peugeot... They then said, Peugeot has a back order of parts so could take and unknown amount of time.
Has anyone else heard of this? Its been two weeks now and I'm dying for my car back...
2004 Black 206, 1.6 HDI GTI.
My Old Pug New one to come!
Lecktorious
PostPosted: Wed Aug 07, 2013 5:27 pm Up
Trade Rating: +59
Find out what parts it is and approach Peugeot direct. Never had to wait more than 10 days for parts, including back order from France.
'98 Nile Blue 306 GTi 6
Royceybaby
PostPosted: Wed Aug 07, 2013 5:33 pm Up
Good idea, I will find out tomorrow, and post back to you guys! Thanks
PostPosted: Thu Aug 08, 2013 12:10 am Up
EBay spares & repairs, let some other mug have the problem.
FYI: they stopped production of this engine a few years back, its now obsolete.
iainlovatt
PostPosted: Thu Aug 08, 2013 2:34 am Up
Should have had it serviced. Sad
Just buy a complete engine and send it to the garage and just get them to fit it. Would be cheaper than £1500. Last time we had a engine fitted it cost £400
(My Garage)
PostPosted: Thu Aug 08, 2013 6:34 am Up
So how does that differ to the 1.6 HDI engine available now?
PostPosted: Thu Aug 08, 2013 7:54 am Up
I would just replace the whole engine. Unless a specialist rebuilder was doing the work, I wouldn't trust the engine again.
www.ebay.co.uk/itm/PEU...232d0ea9c9
Cheapest on Ebay.
PostPosted: Thu Aug 08, 2013 9:28 am Up
Thumbs Up What He Said ,Well it's always to replace the whole engine instead of rebuilding it,because engines done by the factory is much better than any garage,and the cost of rebuild is very expensive I say,don't worth that,so get a second hand engine or maybe a brand new one if you are lucky,and got it serviced :),new cam belt,water bump,....etc.
PostPosted: Thu Aug 08, 2013 9:32 am Up
16 valve version of DV6 killed of in 2011.
Current version of DV6 is only an 8 valve unit.
PostPosted: Thu Aug 08, 2013 11:02 am Up
5 quid says it broke the followers and thats it
Slap a new belt on and see, shouldnt cost more than 200 to fix if you do it yourself
PostPosted: Thu Aug 08, 2013 1:33 pm Up
+5
DIY rebuild and you're laughing.
HDI90
PostPosted: Thu Aug 08, 2013 4:04 pm Up
1500 is more than the value of the car mate, must be mad
GTI 180
chris_h
PostPosted: Fri Aug 09, 2013 6:45 am Up
my cam belt went, only cost 400 quid to sort.
8 new valves, new cam belt kit, cylinder head skimmed, new gasket, oil filter, fresh oil and new engine coolant...
unless it did more damage than this, 1500 quid is a rip off
oh and i did it doing 60 mph
