Latest: eltel666
Overall: 17146
Online Now [84]:
Visitors: 83
Today: 28260
Total: 116219791
Forums › The Car › 206 Talk › which part is the dpf and which is the cat?
vickys.hdi.gti
PostPosted: Tue Aug 13, 2013 1:46 pm Up
Had to remove the aircon condenser as it had a hole in it. (how come it is the most expensive 1?) and while it is out i thought i would clean out the dpf with a pressure washer. But is it the top part or bottom part that is the dpf? Ps where is the option for adding a picture?
Hdi power
Tolkienfan001
PostPosted: Tue Aug 13, 2013 1:59 pm Up
Trade Rating: +13
To add a picture use something like photobucket.com/
I also have a broken aircon condenser! Where did you get your new one from? I have been quoted £262 to supply fit test and regass mine.
In terms of the dpf I cannot help sorry I do not know. I am sure someone will be able to help though....
2005 1.4 16v Sport
Check out my 206 here!
vickys.hdi.gti
PostPosted: Tue Aug 13, 2013 3:17 pm Up
Condenser is around £130 and the regas is free as it wasn't picked up when the gas was done. I fit it myself.
Hdi power
Tolkienfan001
PostPosted: Tue Aug 13, 2013 3:21 pm Up
Trade Rating: +13
Where did you get the condenser from? Was it easy to fit?
2005 1.4 16v Sport
vickys.hdi.gti
PostPosted: Wed Aug 14, 2013 2:31 pm Up
Autokool ltd. it was £117.00 and if you are good at taking your time to remove parts and feel confidant then yes it is easy to fit. mine arrives tomorrow. I spent all today jet washing my dpf out and refitting it. best thing is you can remove the bottom of the dpf while the top stays in place.
Hdi power
PostPosted: Wed Aug 14, 2013 3:03 pm Up
Aren't most of the fittings crimped?
PostPosted: Thu Aug 15, 2013 1:01 am Up
You wont be able to clean the dpf with a pressure washer. Ive tried Laughing
Its the bottom removable half
vickys.hdi.gti
PostPosted: Thu Aug 15, 2013 3:42 am Up
i have spent all day yesterday pressure washing it and now the water runs clean and easy out of the bottom.
Hdi power
vickys.hdi.gti
PostPosted: Thu Aug 15, 2013 3:43 am Up
I have no crimped fittings.
Hdi power
