Latest: Puggingalong
Overall: 17129
Online Now [219]:
Visitors: 218
Today: 25929
Total: 101318888
Forums › The Car › 206 Talk › 206 sport factory spec
steviebee
PostPosted: Thu Aug 15, 2013 4:59 am Up
I have a 2005(march) 206 2.0 HDi sport( well it's the wife's really) and was wondering as to what the spec was as it left factory. I have tried to get on service box without any luck. I would like to install a PPT40 MF Display in the car, but on checking the stalk found it has no internals. Could some kind person be able to find out its spec for me Vin no is VF32JRHYF44534027.
Thanks in advance.
Steve.
frenchie steve
Lecktorious
PostPosted: Thu Aug 15, 2013 5:31 am Up
Trade Rating: +59
Vehicle characteristics
Vehicle family 206
Build code 10304 83 1 0591
Warranty Start Date 31/03/2005
BER e2*98/14*0174*07
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 206
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL X LINE
ENGINE TURBO DIESEL DW10TD
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EXL - PAINT OBSIDIAN BLACK
INTERIOR TRIM TYPE ANDORRE PLAITED CLOTH + EFKA "PA"
UPHOLSTERY COLOUR "FU"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EW/DW
OTHER BADGE WITHOUT FULLER BADGE
BADGE WITHOUT BADGE
TRIM LEVEL X LINE
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X19
Fuel supply-Engine
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 2-COMPONENT CATALYSER 50 PPM LOWER PLATE
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
OPTIMISATION OF VEHICLE’S CONSUMPTION WITHOUT FUEL CONSUMPTION OPTIMISATION
COOLING MOTOR RADIATOR TH: 27-21 DM2 THREAD 1,1 WITHOUT CLPIS IN
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN - 2 SPEEDS 250W 70WAERO
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 70
WHEEL STYLE 15 INCH SIROCCO WHEEL
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
GEARBOX TYPE (TYPE APPROVAL) GEARBOX BE4/5 L TYPE
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 77
TYRE (SIZE, TYPE) 195X55X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 20
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT ABS TEVES MK70
STEERING (OPERATION) ASSISTED MANUAL STEERING
PEDAL BRACKET (TYPE) PEDAL STANDARD
Body fittings
HORNS HORN STANDARD
AERIAL SHORT AERIAL WITH IMPEDANCE ADAPTOR
FINISHER (SELF-ADHESIVE) WITHOUT DOOR PILLAR DECORATION
SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BULKHEAD + BONNET + GMP SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK PLUG FRONT FACADE
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR FRONT/REAR SPORT BUMPER WITH RUSH
MUDFLAP REAR WHEEL FRONT MUDFLAP
LUGGAGE RACK MOUNTING WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) EXT MIRROR ASPHERICAL GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER FRONT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVER WITHOUT LUGGAGE COVER
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING HEATER MATRIX WITH REAR HEATING
SPEED GRADUATIONS GRADUATION MPH
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE CONSOLE WITH REAR HEATING
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT SHINY FASCIA + BLACK BUTTON
MISC. INT. LAMPS LESS INTERIOR LIGHT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 210 KM/H OR 135 M/H ALUMINIUM LAND
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
PROTECTIVE COVER WITH PROTECTIVE BATTERY COVER
RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT ADJUSTMENT DRIVERS FIXED LATERAL BEARING
FRONT PASSENGER SEAT ADJUSTMENT PASSENG FIXED LATERAL BEARING
DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
CLOCK WITHOUT CLOCK
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ON-BOARD COMPUTER NO COMPUTER
EQUIPMENT PACK W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) NEUTRAL FINISH INSIDE DOOR HANDLE
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
STORAGE (DRIVING POSITION) GLOVE BOX + NEUTRAL SWITCHPLATE
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
STORAGE (OTHERS) STORAGE COMPARTMENT FR + RR DOORS + WALLET
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
CARPET NEEDLED CARPET DILOUR F550
LIGHTING TIMER NOT ADJUSTABLE TIMER
SWITCH ELECTRONIC ANTI-THEFT KEY
TRIM ADAPTATION GEAR LEVER KNOB PLASTIC+CHROME INSERT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
STORAGE SPACE LOCKS GLOVE-BOX WITHOUT LOCKING
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORN STANDARD
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
MULTIPLEXING MULTIPLEXING ASSEMBLY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION PACK AIR CONDITIONNING 2
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITHOUT FIRST AID BOX
RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
'98 Nile Blue 306 GTi 6
The larger 3 line PPT 40 display will work fine.
You only need the button on the end of wiper stalk for the trip computer functions.
steviebee
PostPosted: Thu Aug 15, 2013 6:05 am Up
WOW!, That was quick. Many thanks Lecktorious and MrBSI for your replies much appreciated.
Regards.
Steve.
frenchie steve
PostPosted: Thu Aug 15, 2013 7:04 am Up
Not sure if some functions will need activating in the BSI using PP2000.
steviebee
PostPosted: Thu Aug 15, 2013 10:20 am Up
Took the end cap of the wiper stalk and had a poke with a cocktail stick. Radio display changed from radio to date, so assume that's ok. Just need to get a ppt40.
Edit, and the button.
frenchie steve
steviebee
PostPosted: Thu Aug 15, 2013 11:55 am Up
Just a thought, can you buy just the button new from Peugeot. If so any idea how much?
frenchie steve
