Latest: tbafonso
Overall: 17130
Online Now [59]:
Visitors: 58
Today: 41173
Total: 103550394
Forums › The Car › 206 Talk › Does my car have remote central locking?
Go to page Previous  1, 2
tyler56895
PostPosted: Fri Sep 13, 2013 4:53 am Up
I've got a simillar issue regarding a remote key. My car is a 1.4 hdi verve, 2006, came with one remote and one standard key. When my son passed his test I decided to buy a second hand fob off eBay, took the blade and imobilser chip out of standard key and tried the re-synch method in the handbook, but it would not work. Took it to an auto locksmith who reset the whole system charged me £40 and still no good. He confirmed that his manual said my car should work with 2 remotes and that eBay fob was transmitting on the correct frequency.
Is my eBay fob faulty or am I missing something?
PostPosted: Fri Sep 13, 2013 6:13 am Up
It depends how the BSI has been set up. Some allow 2 remotes, others only 1.
Don't know what the locksmith did to reset the whole system. I know you can clone remotes and immobilisers, but the easiest way is to pair them using PP2000 and the security code that was supplied at point of sale with the car.
tyler56895
PostPosted: Fri Sep 13, 2013 6:35 am Up
the locksmith had a black box, which he connected to something under the dashboard, I've had the car since new, so was able to supply the code.
What is a PP2000?
PostPosted: Fri Sep 13, 2013 7:55 am Up
tyler56895 wrote:
What is a PP2000?
Click here
PostPosted: Fri Sep 13, 2013 9:27 am Up
Wont work as the 2nd hand keyfob has NEVER been coded to the car with Peugeot Planet.
ALL resync is for it to get an original coded fob working again after you change the remotes battery.
tyler56895
PostPosted: Fri Sep 13, 2013 9:46 am Up
That's interesting, I was thinking my eBay fob was at fault, so hopefully it just needs synching using the PP2000.
It that something that is easy if I find somebody local or will I need to go to dealer?
Page 2 of 2
