Online Now [104]:
Visitors: 103
Today: 82056
Total: 105975987
Forums › The Car › 206 Problems › Door actuator (central locking)
TJsmith
PostPosted: Thu Oct 17, 2013 12:40 pm Up
Good eveningggggggg,
I'm after a bit of guidance. Basically I've finally got a new door actuator.... However, it requires me to replace the wiring harness that I already have for a new updated one to fit the new actuator I have.
Here's my problem... The wiring scheme is basically done by number but the wires in my car have no numbers/not readable numbers.
If anyone has done this before then I need help, need to sort this so I can sell the poor thing aha.
Anyway. Thanks for your help in advance
Here's the current wiring harness:
Here's the new harness I need to wire:
Here's the wiring setup I need to follow (right hand door):
PostPosted: Thu Oct 17, 2013 7:56 pm Up
Pre-Plex or Multi-Plexed?
Simple locking or deadlocking?
TJsmith
PostPosted: Fri Oct 18, 2013 1:10 am Up
I'm not sure whether it's preplexed or multiplexed? It only has a time display in the middle if that helps? And it does deadlock, thanks for replying mate
PostPosted: Fri Oct 18, 2013 5:20 am Up
Click here
TJsmith
PostPosted: Sat Oct 19, 2013 6:00 am Up
My car is pre-plexed Smile
TJsmith
PostPosted: Sun Oct 20, 2013 3:34 pm Up
Bump, need to get this sorted Sad
PostPosted: Mon Oct 21, 2013 3:01 am Up
Pin 1 Not connected
Pin 2 6202 (Brown)
Pin 3 6232 (Orange)
Pin 4 M6240 (-Ve)
Pin 5 6292 (Blue)
Pin 6 693 (Orange)
Pin 7 6212 (Brown)
Pin 8 6222 (Pink)
Pin 9 6293 (Grey)
TJsmith
PostPosted: Mon Oct 21, 2013 4:51 am Up
Cheers for the reply macca but the adaptor I have is a 6 pin? 5 wire?
PostPosted: Mon Oct 21, 2013 5:16 am Up
Then you have the simple (Non deadlocking) wires.
The pins used for that one are 2, 3, 4, 6, 7. Wire codes and colours are the same as above. Basically brown is the solenoid and orange the switch.
The numbers should be stamped on the wires, I can see some in the picture. You might need to look further up the loom to make them out clearly.
I'm guessing it's the front door from the picture you have put up of the sheet of paper.
TJsmith
PostPosted: Mon Oct 21, 2013 7:58 am Up
ahh okay, how come the sheet I got from Peugeot is telling me to put the 692 in number 1? im stupidly confused, apologies if im being a noob.
I have tried looking further up the cabling but the tape residue seems to have smudged everything on them.
it is indeed the RH Front door,
Again, thanks for replying!
PostPosted: Mon Oct 21, 2013 8:42 am Up
692 is the cable that runs from the BSI and joins onto 693 (guessing the cabin loom and the door loom numbers)
Surprised that any Peugeot part isn't a straight swap.
If I was doing it I would do
Old connector New connector
Pin 2 --------> Pin 3
Pin 3 --------> Pin 6
Pin 4 --------> Pin 2
Pin 6 --------> Pin 1
Pin 7 --------> Pin 5
Only thing I can think off for the different connectors is that they have changed the design of the actuator.
Have they supplied the correct part? It should be 9136** (7 variants)
TJsmith
PostPosted: Mon Oct 21, 2013 2:52 pm Up
Well basically I got a second hand actuator from the scrappy but apparently Peugeot reckon they changed the wiring loom connection late 2001 or something? So I need the new loom to modernise it. I'm not at home this evening but shall check the part tomorrow then give the wire suggestion you've given a go. Really appreciate your help mate
PostPosted: Tue Oct 22, 2013 4:44 am Up
Peugeot changed the electrical system in 2001 from pre-plexed to multi-plexed, so the connection will have changed then.
This is about the best I can do to show you the difference between the 2, but it should help you get the wires in the right place.
TJsmith
PostPosted: Wed Oct 23, 2013 5:53 am Up
Will be giving this a go tonight! fingers crossed, thanks for all your help buddy!
TJsmith
PostPosted: Wed Oct 23, 2013 12:24 pm Up
All sorted macca! Cheers for all your help buddy!
