Latest: Puggingalong
Overall: 17129
Online Now [338]:
Visitors: 337
Today: 63759
Total: 101758674
Forums › The Car › 206 Problems › Burning smell after driving a short while
Barnard85
PostPosted: Mon Dec 02, 2013 3:44 am Up
Hi,
as described, after i have been driving for a short while the car starts to give off a rubber like burning smell.
Its only been going on about a week but has got worse.
I have a 2000 1.4 Roland Garros Auto.
Any help would be rather helpful.
thanks in advance
Karl.
DREWDEN
PostPosted: Mon Dec 02, 2013 6:46 am Up
Don't suppose you have had a new clutch fitted recently, can smell a bit whilst bedding in.
Check front and back brakes after a run out, touch the drums and calipers and see if excessive heat is coming off any, you will know if any are sticking by compareing.
206 2ltr Hdi glx 53 plate
ukskater01
PostPosted: Mon Dec 02, 2013 7:07 am Up
Check what Dresden says, also check your aux belt as it could have stripped a tooth
PostPosted: Mon Dec 02, 2013 1:15 pm Up
It's Automatic Wink
Well make sure that your cooling fans are working,because it might be over heating causing this smell.
Barnard85
PostPosted: Tue Dec 03, 2013 4:26 am Up
the fan kicks in all the time, has done since i bought it back in may..
the car can be running for 2 mins from cold and the fan kicks in.
Brakes are good already thought of that one myself..
DREWDEN
PostPosted: Tue Dec 03, 2013 5:46 am Up
Check your coolant temperature sensor. Green plug
PostPosted: Tue Dec 03, 2013 11:10 am Up
Make sure nothing is touching the exhaust, especially the hand brake cables
2stroke
PostPosted: Tue Dec 03, 2013 11:19 am Up
have you had an oil change recent ? sometimes a bit of oil gets onto the exhaust manifold and gets burnt off.
are your oil and coolant levels staying constant ?
