Latest: tbafonso
Overall: 17130
Online Now [138]:
Visitors: 137
Today: 73379
Total: 102917163
Forums › The Car › 206 Problems › 1.4 16v Flat spot at 2000rpm
ciaran.mooney
PostPosted: Sun Dec 15, 2013 5:09 am Up
Morning,
I've been having a problem with my 206 (2005 reg, petrol) recently
There is a flat spot in the engine response at around 2000rpm. The car can be hesitant and juddery when at 2000rpm. Above and below this the engine seems to run fine.
I have had an engine light come on along with "Antipollution Fault". After checking this with my code reader it turns out to be a P0170 "Fuel Trim Bank 1" fault. The freeze frame data shows that the engine was running rich at the time.
I don't really know what else to do and would appreciate any advice people have to offer.
The car was serviced only a few months ago at a peugeot dealership, so there are new spark plugs etc.
It's not the most annoying problem as I can change my driving style to accommodate the issue however you sometimes want that extra pull.
PostPosted: Sun Dec 15, 2013 7:37 am Up
There's your problem right there.
ciaran.mooney
PostPosted: Sun Dec 15, 2013 8:11 am Up
Are you suggesting that the spark plugs are the cause of the problem?
