Latest: Beduff1977
Overall: 17134
Online Now [651]:
Visitors: 650
Today: 95142
Total: 108727312
Forums › The Car › 206 Problems › Cigarette lighter bulb?
jamie-38-206
PostPosted: Sun Jan 12, 2014 3:05 pm Up
Hi, my cig lighter works fine and gives power fine. But I was sure when I bought the car the outline of the base light up when car lights on. now does not light up. how do i change bulb. are spare bulbs easily available?
Many thanks
commandosqueak
PostPosted: Sun Jan 12, 2014 3:11 pm Up
bulbs are available from halfords and are the same for the mfd and heater controls, its do able but a pain in the a**e
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Sun Jan 12, 2014 3:15 pm Up
I couldn't work out how to replace mine.
commandosqueak
PostPosted: Sun Jan 12, 2014 3:26 pm Up
the easiest way is to take the console out and replace the whole unit
millow_99
PostPosted: Tue Jan 14, 2014 10:21 pm Up
Indeed, I tried replacing mine. Its a Pita to replace that bulb since you need to take it apart and there is a tiny piece of metal which makes contact that usually breaks upon touch. One thing thats easier is to just replace it. Even Clios have the same unit, so plenty.
Have a look, the bulb is in the housing to the south. A PITA to take out.
Pug Lover!
