Posted: Fri Jan 24, 2014 7:16 am |
hi newbie here
got a whining noise from os driveshaft area well a granting noise aswell been like this for two or three months but now its a rubber burning smell after a few miles noise there if clutch in or coasting, knocking worsen when cornering wheel bearings are fine,cv joints seem fine iam at a loss the noise seems more in the centre near the intermediate bearing
thanks ian.
| | ![](images/spacer.gif) |
Posted: Fri Jan 24, 2014 7:30 am |
Brake pads doing alright?
Posted: Fri Jan 24, 2014 7:34 am |
yes there fine newish pads and disc's
the car has started to like hold back like a binding brake but i can asure its not the brakes
Posted: Fri Jan 24, 2014 8:21 am |
Clutch?
Posted: Fri Jan 24, 2014 10:08 am |
Wheel bearing... ?
Posted: Fri Jan 24, 2014 11:19 am |
More apparent in lower gears?
If it is, probably first motion shaft bearing in the gearbox has gone
| Team Impossible Possible
Posted: Fri Jan 24, 2014 2:45 pm |
its there all the time,the worrying thing is the burning smell
Posted: Fri Jan 24, 2014 6:25 pm |
Check your auxillary belt, if loose, or any pulleys going bad.
| 206 2ltr Hdi glx 53 plate | |
