Online Now [54]:
Visitors: 54
Today: 3224
Total: 105011683
Forums › The Car › 206 Problems › Creaking Noise
Creaking Noise
Releh
PostPosted: Tue Apr 15, 2014 4:41 pm Up
Hey,
Got a slight problem with my 2001 206 GLX, Before it's MOT last month it had a creaking noise from the front of the car from both side's. Had the MOT done of which it failed on-
.Offside front suspention arm has excessive play in a ball joint
.Nearside front droplink anti-roll bar has excessive play in a ball joint
.Offside frount droplink anti-roll bar has excessive play in a ball joint
all this was replaced, it passed it's mot and the creaking went however a week or so later it came back.. it's only when going under 40mph that you can hear it/ going over speed bumps or in rough terrain ect.. (I live in the country so it's fairly irritating but it really does not sound healthy at all.
Just wondering if anyone could enlighten me on what the problem could be so i can see if there is a way to get it repaired cheaper than taking it back to the garage
ukskater01
PostPosted: Wed Apr 16, 2014 12:14 am Up
Could be top mounts but you normally get more of a knocking sound. Take it back to the garage and ask them to have a look. Get a quote for what needs to be done, then phone around and you might be able to get it done cheaper else where
chewbacca
PostPosted: Wed Apr 16, 2014 9:10 am Up
check that the large torx bolts between chassis and suspension arms are tight,if they re not fully tightened it gives that creaking noise at low speeds that you mention.
kind regards Thumb Up
Releh
PostPosted: Sat Apr 26, 2014 5:09 am Up
Thanks for the feedback guys, looking into it all today hopefully get it sorted Smile
