Online Now [40]:
Visitors: 39
Today: 80651
Total: 105974585
Forums › The Car › 206 Talk › front wiper without arm cover
19Connor92
PostPosted: Sat Apr 26, 2014 6:29 am Up
any one know what front wiper i need in order to achieve this look
TelaKeppi
PostPosted: Sat Apr 26, 2014 6:33 am Up
Its a standard LHD wiper setup.
206 1.4 HDi
19Connor92
PostPosted: Sat Apr 26, 2014 6:35 am Up
do you know if they will fit RHD? ta
mtempsch
PostPosted: Sat Apr 26, 2014 6:52 am Up
As far as I know (remember since I looked at getting a one-arm viper setup, which AFAICFO they only made for the RHD setup), all the holes in the metal panel for both LH and RH drive setup are there (at least the extra for a RHD setyp on an originally LHD car), so it would be a matter of cutting the holes in the plastic (or get a LHD plastic panel) and getting a LHD linkage.
You might want to check the regulations for sweep coverage/area...(if it's a road car) Doubt Peugeot would have gone for two different mechanisms if they could have used just one. Could get you a pic of the swept area on my car (LHD) if you want.
Silvermetallic 2004 206 RC
19Connor92
PostPosted: Sat Apr 26, 2014 6:58 am Up
yes of course very true was just thinking whether it was worth the hassle or just to get the cover colour coded to my car. thanks for your advise
doski
PostPosted: Sat Apr 26, 2014 7:33 am Up
colour code it if you like the look of it you can get the paint for around £10 a can and have a go yourself if you fail its only £10 down the drain.
I wrapped mine in carbon (makes it lighter aha) but on a serious note it was around £5 for a 1m sheet and i did the cover and the wing mirror covers as they had faded
PostPosted: Sat Apr 26, 2014 10:59 am Up
The right hand drive wiper set up sweeps more of the screen on the right where the driver sits in a UK spec car.
