Latest: Stu-mill
Overall: 17131
Online Now [38]:
Visitors: 37
Today: 6743
Total: 104916394
Forums › The Car › 206 Problems › 206 1.4 Petrol Lambda sensor
elliott90
PostPosted: Wed May 14, 2014 3:53 pm Up
I've got a 2006 1.4 petrol giving an P0130 with a cheapy OBD2 reader which also shows a relatively constant 0.2v from the sensor. Idles are a bit lumpy, and I though MPG was a tad low (measured at ~40mpg on a couple of hundred miles of motorway at mostly 65mph and being pretty steady, so not horrendous but I've read of people getting 45+).
It also seems to lack power between 2000-3000 RPM, in 5th at ~65mph it was decelerating on a very gradual hill (motorway) - could this be the lambda or another problem?
I'm looking on ECP and there are a bunch of sensors at various pricess, only some state whether they are pre or post cat. Does anyone know which sensor is for this engine or will they all work?
Cheers.
PostPosted: Fri May 16, 2014 5:53 am Up
I recommend that you get a proper diagnostic done by a PP2000,so you know exactlly what is wrong,as replacing the O2 sensor is not cheap,specially when you buy a decent brand,or an OEM one.
