Online Now [48]:
Visitors: 48
Today: 5540
Total: 105013986
Forums › The Car › 206 Problems › Headlights Sticking On?
206Tom
PostPosted: Wed May 28, 2014 5:16 pm Up
Hi,
2002 GLX with auto lights.
Basically the headlights are sticking on after engine has been turned off. They are on auto mode atm but surely they should switch off automatically when the key is removed?? PP has shown no faults with this!
Only way to turn them off seems to be to flick the side lights on, then off, and all lights go out.
...well not quite all lights, brake lights are a permanent feature atm but will be checking the the switch above the glovebox for those tomorrow.
Cheers
Tom
bodieanddoyle
PostPosted: Wed May 28, 2014 5:33 pm Up
I had similar only mine doesn't have auto lights. After driving with lights on intermittently switching tge car off the lights stayed on. A quick flick of the switch puts them off. I had corrosion on some of the terminals on my bsi unit from a water leak. Stiff nylon brush, contact clean and terminal grease seemed to fix it. Might not be your issue just sounds similar.
drives a little green deep fat fryer. 1.4 hdi sw.
206Tom
PostPosted: Thu May 29, 2014 4:16 am Up
Ah ok thanks, looks like both this and the fuel fault could both be caused by BSI then! Definitely be checking/cleaning BSI contacts later and hope it helps!
206Tom
PostPosted: Thu May 29, 2014 11:15 am Up
Looks like I might just be impatient lol....
The lights do turn off, but only when the mileage display goes out, I'll assume that's normal then lol, oops.
PostPosted: Thu May 29, 2014 11:24 am Up
PostPosted: Thu May 29, 2014 11:27 am Up
Sounds like the light sensor has a fault plus your running a very early BSI software version.
Sounds like the early follow you home headlamp function is being triggered by a faulty light sensor on the screen.
Disable the auto headlamps & see what then happens.
A BSI reboot or even better a BSI software update might be a good idea.
206Tom
PostPosted: Thu May 29, 2014 1:32 pm Up
macca1411 wrote:
Ah, excellent, cheers! I don't have a handbook unfortuately. That sounds right though....but 45 seconds is a long time tbf. Last car I had with auto lights (albeit not a Peugeot) switched them off immediately.
Looks like one less fault than I thought then. Very Happy
DREWDEN
PostPosted: Thu May 29, 2014 3:33 pm Up
public.servicebox.peugeot.com/ddb/
Handbooks here just change to Englist top right
206 2ltr Hdi glx 53 plate
206Tom
PostPosted: Thu May 29, 2014 4:14 pm Up
Ah nice one! Been using servicebox for years and never realised they were on there lol.
