Latest: tc.206
Overall: 17147
Online Now [172]:
Visitors: 171
Today: 9640
Total: 116506206
Forums › The Car › 206 Problems › Normal running temprature
coolhas
PostPosted: Mon Jun 09, 2014 2:01 pm Up
Hi guys what's the normal running temp for 206 52 plate 1.4 mines always on about 100 them back to ninety then 100 again then back again think my head gaskets gone so trying to figure it out also have oil in coolant no coolant in oil had oil cooler changed
PostPosted: Mon Jun 09, 2014 3:09 pm Up
The running temp. u got is the normal,and perfect one,as it should be between 90 to 100,as fans kicks in about 97.,so yours is automatic?
coolhas
PostPosted: Mon Jun 09, 2014 3:20 pm Up
Yh automatic mate not got the gunk In coolant fixed getting the head gasket done tommarow mate u say normal but should that be happening constantly also when I turn of the ignition and turn it back on its past the hundred the fans kick in again
coolhas
PostPosted: Mon Jun 09, 2014 3:27 pm Up
Also when I open my bonnet there is a huge amount of heat I mean huge too hot more the normal ,what do u think that suggests
PostPosted: Mon Jun 09, 2014 4:34 pm Up
Thermostat might need changing. Should run around 90.
coolhas
PostPosted: Mon Jun 09, 2014 5:34 pm Up
Had that changed do you think it's stuck or it's opening late
coolhas
PostPosted: Wed Jun 11, 2014 9:12 am Up
Hi my temp gauge is on around a hundred and then back to 90 constantly is this the normal had my head gasket done too now so it's the same before and after
PostPosted: Wed Jun 11, 2014 9:35 am Up
Topics merged
Nath189
PostPosted: Thu Jun 12, 2014 4:35 am Up
Hi I have a 2.0 hdi and my temp doesn't go higher than about 75 while driving but will creep up in traffic have I got a problem some where?
PostPosted: Thu Jun 12, 2014 6:04 am Up
Radiators on these cars are old now. Could be a corroded radiator. Are the fins on it all knackered?
sean.r.steward
PostPosted: Thu Jun 12, 2014 2:43 pm Up
Check it with a lazer tep gun. Check all pipe are hot. Bleed system get rid of possable air locks. Pull return pipe to expansion bottle to see if there's circulation. Flush system.
there's a few things to try
sean.r.steward
PostPosted: Thu Jun 12, 2014 2:48 pm Up
Reread topic change head gasket. No point p**sing around with trying to fix cooling system if its being contaminated with oil
coolhas
PostPosted: Thu Jun 12, 2014 3:03 pm Up
Had the head gasket done but same issue with the temp I'm bamboozled
sean.r.steward
PostPosted: Thu Jun 12, 2014 3:07 pm Up
oo sorry, well give these a go then mate
