Latest: Beduff1977
Overall: 17134
Online Now [1879]:
Visitors: 1878
Today: 133936
Total: 109988452
Forums › The Car › 206 Problems › Ticket area on windscreen
pewe
PostPosted: Sun Jun 15, 2014 6:02 pm Up
There is a spotted area on the windscreen behind the interior mirror which is designed to be non reflective for placing parking tickets etc.
Does anyone know if using sticky tape (double sided) would cause any problems when it comes to removing it later.
I'm thinking of the sort of tape used to attach mounts for dashcam/mobile phone.
Anyone done this?
TIA
PostPosted: Sun Jun 15, 2014 6:16 pm Up
As long as your carefull & don't just scrape it off you'll be fine using & removing it.
pewe
PostPosted: Sun Jun 15, 2014 6:23 pm Up
Sorry, I should have been clearer Embarassed
I wasn't anticipating scraping it off, Shocked but with double sided tape it can sometimes be a pain to get off and I would normally use a solvent (white spirit usually) to remove it. It was that I was concerned about.
copey
PostPosted: Mon Jun 16, 2014 2:03 am Up
furniture polish will remove it
02 2.0 hdi d turbo
pewe
PostPosted: Mon Jun 16, 2014 3:35 am Up
Thanks guys
PostPosted: Mon Jun 16, 2014 10:03 am Up
Heat up what you want to remove with a hair dryer, then pick off what you can. Then you'd be fine using a little bit of white spirit to clear what's left, & finally I'd wipe it over with a damp cloth to get rid of any white spirit residue or smell.
pewe
PostPosted: Mon Jun 16, 2014 6:22 pm Up
Thumb Up
