Latest: airmastertapes
Overall: 17133
Online Now [309]:
Visitors: 308
Today: 605
Total: 106712544
Forums › The Car › 206 Problems › Angel eye covers
Angel eye covers
eteej
PostPosted: Fri Jul 25, 2014 5:09 pm Up
I have just had a set of second hand angel eyes arrive today, they are in good condition other than the inside of the cover, it is filthy in there, I can see that it is attached with clips but the lens doesn't move when you move the clips. Anyone any idea of how to get these off safely so I can clean them before they grace my car?
Cheers
mtempsch
PostPosted: Sat Jul 26, 2014 3:06 am Up
Without seeing the specific ones you've got, most likely the lens is attached to the housing with glue/mastic to make an air/moisture tight seal.
Typical procedure for splitting headlights is [real careful] use of a hot air gun or powerful hair dryer along the seam. Or heat the entire thing in the oven at about 75-100 degC, then possibly combine with hot air gun / hair dryer if it proves stubborn.
Start low and increase heat only if things don't give.
Use gloves to protect your hands as you pull the pieces apart.
Silvermetallic 2004 206 RC
tomhollo21
PostPosted: Sat Jul 26, 2014 3:48 am Up
I used a hot knife to cut through the old sealent when I did mine
