Latest: tbafonso
Overall: 17130
Online Now [80]:
Visitors: 80
Today: 10933
Total: 104647267
Forums › The Car › 206 Problems › 180 axle.
180 axle.
Jtktm1989
PostPosted: Fri Aug 01, 2014 2:55 pm Up
Just want some quick info on what a upgrade to a 180 axle would be like on a 138 model.
PostPosted: Fri Aug 01, 2014 4:32 pm Up
Very slightly stiffer.
