Latest: tbafonso
Overall: 17130
Online Now [79]:
Visitors: 78
Today: 29234
Total: 103477049
Forums › The Car › 206 Problems › Identify my temperature sensor?
JordHaze
PostPosted: Sun Aug 03, 2014 6:20 am Up
Hi guys,
How do I identify my temperature sensor?
I know I need a new one, but I don't know which one I need. I was planning to go to the Breakers yard and see if that fixes the problem. (I'm selling the car as soon as the few problems are fixed)
I also need to know if it matters hugely on what coil packs I put in? Would you advise brand new or could I go to the breakers yard as well?
Cheers,
Jord
My 206 Project Thread
PostPosted: Sun Aug 03, 2014 8:06 am Up
Coolant sensor is usually green. Your car might have two sensors one might be a different colour.
JordHaze
PostPosted: Sun Aug 03, 2014 8:43 am Up
Could anyone possibly tell me whether my 206 Look (57 reg, 1.4l engine) has 2 sensors?
PostPosted: Wed Aug 06, 2014 3:52 pm Up
1.4 8V or 1.4 16V. With or without aircon.
PS: the Haynes manual isn't perfect for these cars but does explain which sensors are on which cars. While not cheap a Haynes manual is a good investment if you DIY.
